Brembo piston stick :(
Old Sep 10, 2015 | 02:15 AM
CahitGP034's Avatar
So i realized that while i put my foot on the brakes the car will shake really badly and turn to the left becouse its happening to the left caliber is there any video or anything that could help me fix it up temporarily ? after getting new brake bads after a month thins problem happen :/
Old Sep 10, 2015 | 07:41 AM
Tommyy's Avatar
Warped rotor?
Old Sep 10, 2015 | 08:25 AM
CaptainSquirts's Avatar
Rotors don't warp. You might have built up brake material on your left rotor. Pull it off and if you have spots where it has a lot of built up/uneven brake material then sand it down.
Old Sep 11, 2015 | 09:29 AM
LetsGetThisDone's Avatar
Uneven pad deposists won't make the car pull. He likely has a stuck caliper. You can get caliper rebuild kits from Girodisc..
Old Sep 11, 2015 | 01:42 PM
GTijoejoe's Avatar
You may need a caliper rebuild.
If the piston is actually sticking, you either need a new piston or most likely the seal is bad.
Seals have roll back, which pull the pistons back.
Old Sep 11, 2015 | 02:43 PM
Pistons don't really go "bad". They can however get some corrosion build up, which can be bead blasted, or polished off..
Old Sep 12, 2015 | 10:46 AM
killerpenguin21's Avatar
the dust boots harden and can limit piston motion. i replace my boots once a year for track purposes. the issue is if its been like that for awhile, you can score a piston.
Old Sep 12, 2015 | 11:18 AM
GTijoejoe's Avatar
Actually they do. When it corrodes and pits, then you bead blast, you are changing the diameter of the piston and the surface finish. These characteristics are designed into the piston and seal interaction, not to mention removing the surface plating
Old Sep 13, 2015 | 11:01 AM
I've never had a piston get corroded that bad. So I guess its possible..
crcain
Apr 29, 2009 12:38 PM
bradc
Feb 28, 2009 02:19 PM
kkarim
Feb 11, 2008 05:40 PM
gofaster87
Jan 8, 2007 03:30 PM
