Rear camber adjustment
Old Dec 22, 2015, 06:07 PM
WongEvo's Avatar
I recently installed a set of coilovers on my IX, and lowered it slightly. Was wondering what's the best way to get rid of the negative camber? Camber plates vs. camber bolts vs. adjustable LCA's.
Not sure if I take it for an alignment, they can fix the negative camber without installing any of the above.
Old Dec 22, 2015, 06:18 PM
Received 1,384 Likes on 1,317 Posts
Negative camber is part of the stock alignment noted below. How much neg camber was found on your Evo?
Front:
Toe-in mm (in.): 0 +/- 2 ( 0 +/- 0.08)
Camber (Selectable from 2 options): -1deg +/- 30' or -2deg +/- 30' (left/right deviation within 30')
Caster: 3deg55' +/- 30' (left/right devitation within 30')
Rear:
Toe-in mm (in.): 3 +/- 2 (0.12 +/- 0.07)
Camber: -1deg +/- 30' (difference between right and left within 30')
GetFoxed
May 28, 2014 04:19 PM
EndlessRed
Jul 3, 2013 01:03 AM
RedStarr
Aug 10, 2011 11:11 AM
jchild420
Nov 9, 2009 07:01 AM
Late Apex
13
Mar 28, 2006 08:38 AM
Quick Reply: Rear camber adjustment
