WedsSport TC105N or Gram Lights 57Transcend?
WedsSport TC105N vs Gram Lights 57Transcend vs Advan RSII
So I'm in the middle of wrapping my car teal and realized my wheels look horrible on my car now, so I need to get some new ones. I'm currently torn between three wheels, and have no idea which size/offset combo will look the best which them. Any input on the options below would be awesome!
WedsSport TC105N
17x9 +25
17x9 +35 [3mm front spacers required]
17x9.5 +33
18x9.5 +35
17x9.5 +25
18x9.5 +35
Advan RSII
18x9 +25
I will also be purchasing them in a Graphite or Gunmetal if available, and if not they will be powdercoated.
Pictures of the car here: https://m.imgur.com/a/wRlBq
EDIT: These wheels will also mostly be used on the street/shows with a bit of drag racing, but I have Hoosiers I use for racing the majority of the time.
WedsSport TC105N
17x9 +25
17x9.5 +33
18x9.5 +35
17x9.5 +25
18x9.5 +35
Advan RSII
18x9 +25
18x9.5 +35 with a 265/35r18 looks the best on the CT9A for a street car IMO. Will require rolling the rear fender, but it's well worth it.
I'm partial to the weds . I wanted to keep weight,cost and tire size down since I have a 4.11 Final drive. I went with a 17 x9 et35 .There are a lot of options for a lightweight ,sticky 255-40-17 . Keeping rotational weight down is easier on the drivetrain.
Now , if you car makes good power you can go with a 18" 255-40-18 for a taller tire to lengthen the gearing on your car.
You can also exceed the traction limit of the stock oiling system on a well setup 245 or 255 tire . An oil pan and hla help with the oil issues but going to an even wider tire can make things worse if you are really driving it hard.
Originally Posted by Perplex
Id probably go with a 255/35 on an 18. Is there a big difference between Gram Lights, WedsSports, or Advans?
I love my TC105N's however they are expensive, and if you are going to track your car, expect that you will **** up a rim. When that happens you are looking at an expensive fix.
If I could do it over, I would got 17x10 RPF1's on NT01's 275.
I am on 17x9 +35, but running stoptechs in the front so no spacer is required. I also have the evo x LCA and with 3.2* of camber up front they are tucked in really nice. I might buy a 17x10 just to see if the brakes will clear.
evelthui
Dec 10, 2019 02:53 PM
Speed Element
Evo 'For Sale' Wheels / Tires
45
Jan 22, 2010 10:49 PM
Speed Element
EvoX 'For Sale' Wheels / Tires
23
Dec 2, 2009 10:55 AM
Inprogress
Jan 4, 2007 10:27 PM
sashin
24
Aug 17, 2006 04:29 PM
