New Ball Joints and bushings
Hi friends! I am in the process of repairing some bad rust on the rear frame of my IX and I have the rear end completely torn apart. While I am in there I figured I would replace some suspension parts and bushings. Any suggestions on what to get. We mostly spiritedly DD the car. Thank you.
I just went through the same thing. While everything was out I had every bushing replaced with Whiteline bushings and replaced all of the ball joints with the replacements from Hardrace. The ball joints ran me around $300 shipped. All of the other bushings together was a few hundred as well. My gas filler tube was getting tender so I did that while it was easy access as well. That piece was around $120. I replaced all of the hardware as well for safety measures since 2 of the subframe bolts snapped anyways during removal.
Any special methods to extract the broken bolts? Are the Whiteline bushings poly's or rubber?
Yeah it's pretty crazy that these cars are under recall for front subframe and not the rear. Everyone I've talked to with subframe/rust issues has had it in the rear and not the front. My front subframe is still fairly clean but I will have the recall done anyways just to have that front section as clean as the rear. When I had my repair work done I had them do a little extra just so I wouldn't have to worry later down the line. Here are some pics.
As for the broken bolts I couldn't tell you how they did it exactly but if I had to guess I would say they might have welded a nut on the broken bolt stud and extracted it that way since they did end up using new OEM suframe bolts. I don't know if that would have been possible using a tap and die set. The whiteline bushings are poly.
I have tons more pics if you want to see something more specific. Just ask and I'll see what I can dig up.
By the looks of the pictures did the shop weld in a new frame rail?
N1MR0D
15
May 9, 2018 05:50 PM
sfb12
Nov 23, 2016 08:01 AM
WRC-LVR
12
Aug 10, 2012 05:11 PM
FetorHepaticus
Nov 2, 2009 10:57 PM
