Evo 9 front axle play
Old Nov 2, 2017 | 06:43 PM
1hotevo9's Avatar
Hello everyone, I have a question about my front passenger side axle of my evo 9. The axle has a lot play on the output shaft of the transfer case. Video shows movement. My question, is it the bearings in the cv joint causing the play, or the output shaft splines worn out? Or both?
Old Nov 2, 2017 | 07:08 PM
Ive have not tackled this issue yet, but it sure appears that the universal joint has way to much play. Heres an exploded view if needed. Hopefully you can rebuild or just buy a fully refurbished 1/2 shaft
Old Nov 3, 2017 | 09:49 PM
1hotevo9's Avatar
I've come to the conclusion that I'm just going to buy new front axles and see if there's any play with them.
lso should I go with DSS level 0 or level 2? I'm just shy of 400 hp.
hachansoo0413
35
Feb 19, 2020 09:07 PM
Iowa999
11
Jun 25, 2012 10:08 AM
MitsuJoe
10
Oct 2, 2011 08:26 PM
