Interest Thread For Billet Rear Trailing Arms
#108
The last set is just about to get shipped out. I'll get more material on order as soon as I get this latest shipment of stuff cleared out to get another 5 sets but it'll be maybe 6-8weeks before I have sets fully available. Best to follow on IG if you want to keep up to date with what I have in stock since I can't directly advertise here.
#110
I'm going to post these here as well. 18x11" +52 wheels at a reasonable weight of 22lbs.
https://www.apexraceparts.com/wheels...ang-wheel.html
Let's compare them to the 18x10 +38 RPF1s. What are the chances of making this work?
ViciousLSD (Jan 23, 2019)
#111
ViciousLSD (Jan 24, 2019)
#113
#114
I like the idea, I just don't know what's involved in moving the strut further in, or what kind of horrors we might face up front. 11" wheels on a stock body without desecrated fenders sounds awesome. Plus these actually look good, they're cheap, have acceptable weight, and have a fine reputation with BMW track guys.
They also have a 10" +43 version, which I'm probably getting. No reason besides looks, RPF1s are the same price and 3 lbs lighter, but I can't just spend the rest of my life rolling around on RPF1s.
https://www.apexraceparts.com/18x10-...ang-wheel.html
#117
#118
If you look in the picture I posted above, there's about 10-15mm between the shock and the upper control arm. With my billet uprights that increases just a bit with the upper arm angled down about 8 degrees more. My plan is to remake the lower arm to move the mounting point inward enough to get to a happy minimum clearance. Im not necessarily planning this for anyone else because I don't want to worry about what others shocks bodies have for clearance, but in my case I can get more inboard tire clearance which will be critical for the biggest of big rubber.
I may have some slug inserts to make the lower position slightly adjustable to like 0, +5, +10. But I wont make the over all length adjustable. I wont design anything with threads in bending regardless if its oversized. That's just bad engineering.
#119
Thanks for your email and sounds like a really cool build. To answer your question, yes the 18x10" EC-7 will clear your brakes no problem. They offer a ton of room and even clear the newer Mustangs 15" 6 piston setup if you ever wanted to upgrade your brakes in the future. They would also fit even if you didn't run a spacer, there's that much room offered.
