Best wheel width for 265/35R18?
O'l Crankwalker came here looking for some simple 18 x 9 +35 advice & certainly got tangled up w/our aggressive fitment guys
Now he's staring the down barrel at 9.5" to 10" pulling rear fenders & the like
Down the Rabbit Hole
Hang in there. Specing the right W/T for your appetite is a hard decision
I would definitely agree you're over thinking it here. Needing a spacer is NBD. 9" +32 will be just fine in the rear, if the front is a little tight on the inside then add a spacer.
Without knowing how that particular tire fits a 9 or 9.5, it's hard to say.Spacers depend on wheel design. I ran 20mm bolt-on spacers for about two or three years. They held up fine for HPDE and AutoX. I recently put ARP studs up front and knocked the studs out of the spacers. That was for piece of mind because I'm not sure I trust the studs on the spacers. Either way, I haven't found a problem with spacers and I think I remember lots of people in motorsports using them.
Wheels and tires are useful if you feel you have found the limits of the smaller stuff. I.E. I turned a "decent" lap time at Laguna Seca with 235 R-S4s and I'd consider myself a mediocre driver, so you can still have fun even on stuck stuff! On the other hand, If you you are to the point of needing wheels and tires, they will help a lot.
TLDR with a .5" difference, I'm sure you will be fine either way, unless you have a really sensitive butt.
BOOM.
If my fenders weren't already pulled when I got the car then I would have known when to stop.
But you see, people like Dallas are Pennywise and your fenders are the sewers. This might look fun from further away, but once you get close you'll see the paint chips and fender liners with huge scary holes in them. We all angle grind down here.
truth. My fender liners are held in with zip ties because the front of them is pretty much gooooooooooooone.
265s on 18x10 is possible without mutilating the fenders. I even run fender liners without any issues on our bumpy autocross lots. 18x10" requires fine tuning the offset, caster, and camber to make sure everything actually fits, though.
I'd recommend 18x9.5" if you want an easier fitment. Go 18x10" if you want every last bit of performance and you're okay with some extra fine-tuning of the spacers, alignment, caster, and maybe the fender lip.
