ABS light trouble shooting
Old Jun 12, 2020 | 08:30 AM
OZEVOVIILANCER's Avatar
So I've been doing some trouble shooting on my abs light. It gives me a code for a bad front right sensor. Pulled the wheel and fender lining ohmed out the sensor getting a good signal 1480 range so I know that is good. I have the circuit diagram for abs and am trying to get an ohm signal through the harness plug at the wheel to the abs module itself. I don't know if I'm not reading the diagram correctly but I can't find the pin location for the front right sensor on the abs harness. Would anyone know which two it would be before I tear down the car and chase the wires?
Old Jun 12, 2020 | 01:52 PM
XSivPSI's Avatar
I can't help you but what scan tool did you use to pull the code? I haven't had luck with the couple I've tried.
Old Jun 12, 2020 | 02:05 PM
Just used paperclip to jumper ports 1&4 on obd2 turn the ignition on and read the flashes for abs.
Old Jun 13, 2020 | 05:03 PM
osetsky's Avatar
Lol, I'd be too scared to do that to my car...maybe someone else's though!
cocoon
10
Aug 29, 2016 03:25 AM
DarkEvo
18
Oct 12, 2015 07:54 PM
Dangerdave
Jun 4, 2015 06:56 PM
NGC_Evo8
Mar 5, 2013 01:22 PM
xspsi4
May 31, 2007 04:42 AM
