ABS light
Old Mar 4, 2013 | 05:06 PM
NGC_Evo8's Avatar
ABS light
could anyone help me out to maybe see why my abs light will turn on but the sometimes it will turn off so dont really know this guy told me it was my brakes but i looked at them and the pads are still good so dont really know why is it doing that. Its a 2003 mitsubishi evo 8 any help will be appriciated.
Old Mar 4, 2013 | 05:07 PM
NGC_Evo8's Avatar
My bad for all the paragraph errors and stuff
Old Mar 4, 2013 | 05:18 PM
egis's Avatar
try to disconnect the battery,wait 10 min and reconnect.
Old Mar 4, 2013 | 07:10 PM
barneyb's Avatar
He means down by the brakes. There's a sensor for each wheel. The wiring, the sensor itself or the toothed ring could be damaged.
Old Mar 5, 2013 | 07:12 AM
Evo Inferno's Avatar
Check the wiring harness that runs down to each wheel. My ABS light came on about a year ago on my 04. I discovered the wiring harness on the right front wheel, behind the rotor had been severed in two. There is a shield on the back side of the rotor which is what the harness is fastened to. The only thing I could think was it was a result of vibration. I soldered the wire back together with some heat shrink tubing and the problem was solved.
Old Mar 5, 2013 | 09:25 AM
barneyb's Avatar
^^^^what he said
Old Mar 5, 2013 | 11:06 AM
NGC_Evo8's Avatar
Kool thanks for the info ill try that see what works
Old Mar 5, 2013 | 01:22 PM
ProPilot04's Avatar
Also... check your fluid levels.
DarkEvo
18
Oct 12, 2015 07:54 PM
mr.gsr
May 14, 2014 10:58 AM
Silver-IXse
Apr 14, 2014 12:55 PM
blackandredgts
Sep 15, 2013 09:56 AM
bdonIX
Dec 18, 2012 02:22 AM
