2020 Suspension Recommendations
Appreciate the response ✊🏽. I’ll take a look at the rear sway bar tomorrow once I get a chance to get under the car. If the bilsteins are bad (which I hope they aren’t) but if they are, any places still rebuild them for a reasonable fee or at this point would going coils just be my best bet.
Hope this helps
- Jason
Make sure the Bilstein shocks/struts are not seeping oil or leaking oil/fluid. It could be that the shocks are worn, or the spring rates do not match the shocks or a combination of both. To verify the springs are correct you can look for a part # on the spring and cross reference them on Swift's website: http://swiftsprings.wpengine.com/sport-compact/ . If everything looks good, you still may want to have the Bilsteins rebuilt (assuming they are the original ones for an evo).
Hope this helps
- Jason
Hope this helps
- Jason
I had Bilstein MRs with Swift Spec R’s a while back. It should not be bouncy at all. If one is leaking, and you want to dedicate yourself to this setup for years to come, you can send your setup sent out and have the Bilsteins revalved to match the springs much better. I wouldn’t bother just rebuilding one, at min a pair if not all four as they are all likely blown or on there way out.
FS[Northeast]: MR Suspension , Swift springs
Giuna99
Apr 14, 2016 09:22 AM
