Rear Strut Brace recomendation?
Old Apr 21, 2004 | 10:37 PM
kevo's Avatar
What differences do you feel between those bar? What kind of handling characteristic do they give you?
Old Apr 22, 2004 | 06:44 AM
Racer RS X's Avatar
Sorry I have not posted pictures yet. This week has been busy. But I will get them soon.
Changes:
First I added the front Cusco box brace, the type II, I think. It replaced the two lower tie bars. I did not really notice a difference, even in the mountains. The car might have been a little stiffer. Not much.
Then I added the rear strut tower brace, and I did not notice a difference.
Then I added the v-brace, and I notice a difference. The car felt tighter. The ride got a little harder, and more precise. You would feel a bump, but it was a more solid feel. As for handling, I noticed that I needed less steering input through the turn. The car held it's line better in the mountains. Turn-in was a little better.
Then I added the trunk brace. The ride got a little more solid in the back of the car. It felt less like a sedan and more like a coupe. I know the Evo is stiff, but I am comparing it to my RSX that had every bar, brace, dampner that was made. It was a great chassie looking for an engine.
The best way to describe the changes in the Evo is that it is more precise. Less steering input through a turn, even over rough surfaces, and better turn-in.
MYEVO8 has the same bars, except he does not have the trunk bar and he has seen similar results from the v-brace.
Old May 25, 2004 | 03:11 AM
JT-KGY's Avatar
redvolution,
got any pics for the Ralliart rear strut bar?
Old May 25, 2004 | 02:48 PM
hueman's Avatar
racer rs x,
would you say the car exhibits more understeer or oversteer issues, or are they more muted after the installations?
and do you have coilovers? have these mods helped your slalom at all? my stock evo's rear feels like it'll slide out when i corner hard sometime, and wanted something a little more solid feeling.
excellent write up, thanks!!
Old May 25, 2004 | 03:18 PM
oguratevo's Avatar
Get the Mitsu rear strut bar, no hinges, stiff bar ideal for EVO's
Old May 25, 2004 | 03:21 PM
JT-KGY's Avatar
anyone got a picture of it?
Old May 25, 2004 | 03:25 PM
oguratevo's Avatar
Look for it at mitsucars.com or mitsubishiparts.com
Old May 25, 2004 | 03:29 PM
JT-KGY's Avatar
Just did.. no pictures...
Old May 25, 2004 | 03:34 PM
oguratevo's Avatar
Sorry about that, try the ralliart website, ralliart.com.jp, click parts and select suspension.
Old May 25, 2004 | 03:36 PM
oguratevo's Avatar
Oops!! ralliart.co.jp
Old May 26, 2004 | 01:43 PM
Ehutch91's Avatar
Does anybody know the part number for the OEM rear strut tower brace?
Old May 26, 2004 | 10:34 PM
Racer RS X's Avatar
Hey, sorry it took me so long to get back with the pictures and stuff.
Here is the thread with the pictures of my braces:
https://www.evolutionm.net/forums/sh...ad.php?t=82356
As for oversteer and understeer. Understeer is gone from my car. It either oversteers or 4 wheel slides. Drifts are fairly easy too. But, I think this is the effect of my alignment, springs, and harder tires.
The bars mostly tighten the feel, response, in my opinion. They make the car feel more precise. I do not have coil overs, but will be going this route this winter.
As for the rear feel of the car. I would try the trunk bar first. It is only 70 to 80 bucks, and bolts to the factory holes. The only thing is that you have to trim the plastic. But, with the tri-brace, you have to; cut the carpet, cut the covering over the strut towers, and drill holes in your car......the trunk brace takes less effort. Give that a try, it should make the car feel stiffer.
Old May 28, 2004 | 10:32 PM
Evo8RA's Avatar
Here's a link that will get you to pictures of both the RalliArt and Mitsubishi rear strut bars:
http://www.japanparts.com/shop/shop....ird=Strut+Bars
or if that doesn't work, just go to www.japanparts.com and navigate to the Mitsubishi Evo8 - Handling & Braking - Strut bars section
There are some better pictures of the Mitsubishi rear strut bar at www.machevo.com under the Suspension category. Here's a link to try:
http://www.machevo.com/mirestbar.html
Enjoy.
Old May 28, 2004 | 10:55 PM
JT-KGY's Avatar
Thank you!!!
They look nearly identical... It's a bit hard to see the detail of Ralliart's mounting
points b/c of the picture size...
Enjoy.
gptoyz
Aug 24, 2015 11:58 AM
Lukelis
Sep 27, 2014 07:08 AM
Fireescape
26
Jan 11, 2012 08:12 AM
CB
10
Mar 25, 2004 09:52 AM
ErroR
36
Dec 4, 2003 08:23 AM
