Hello hello!
Anyone here had the same issue ? The max camber on the rear left is way more negative than the right
And the right wheel seems to poke more
New toe arms
New bushing for the diff so maybe subframe crooked ?
so what did you do ? Adjustable arms all the way ?
well now I have adjustable toe and control arms(3deg camber). +SSB trailing arms to fit 295s.
its up to you. you can try to get close to the settings you want or make them adjustable to get more
i'd say -2 max is enough for me on the rear for streets and tracks use, i have like -2.5 in the front..
i will see if my alignment shop will be able to put -2 on both side on the rear...
If not, i'll put some adujustable rear camber arms too..
