Rear Anti-roll Bar Install???
hi, i started to install a cusco rear A/R bar, but i'm having difficulty removin the stock bar. i disconnected the links, and removed the bushings, but i can't get bar clear of the subframe, suspension, and driveshafts. i unbolted the muffler also to drob the intermediate pipe. what am i doing wrong?, thanks
http://rbmotoring.com/gallery/album152
We installed the HKS Kansai 3-way adjustable bar in our car. I don't know what your hangup is. Ours came out with no issues.
Originally Posted by SSKILLA
i want to know what roll bars and strut bars are recomended to cange after you lower your evo
What future roll bars you needs depends on what spring rates you end up with and rather or not your car is giving you understeer or oversteer. Correct to much body roll with stiffer springs not sway bars.
Originally Posted by mayhem
I wouldn't waste your time and money changing STBs.
Have you had any issues with damage to the subframe where the larger rear bar mounts?
I had that problem with an Integra GSR I used to have. That car sure did turn in with the big bar, but I am a little shy about the upgrade on my EVO since I had to WELD re-enforcments to the Acura sub-frame.
