Hydraulic Handbrakes
In competition this weekend another EVO and a WRX had hydraulic handbrakes installed. And I was consistently beaten on the hairpins by those 2 cars.
I have a EVO(1-3) can I plumb in a hydraulic handbrake?
I was told I can`t because I have F+C+R ATS LSD`s.
Robert VanLane
TakeTomboRacing
Robert VanLane
TakeTomboRacing
Guest
Posts: n/a
We have GrN Evo 6s here that have hydraulic handbrakes installed. They have front, rear and center diffs. I asked about installing a hydraulic hand brake into mine, and it's possible. You need to replace the hoses going to the rear brakes and make some other minor changes.
Driving wise, you will get people telling you it is bad for the center diff, which is theoretically true. However, I havent yet seen an Evo GrN with a hydraulic handbrake break on of those. It will work better on a Evo 7 where the center diff disengages when you pull the handbrake, but it will be a major improvement, as you can tell by the fact the people with it beat you.
My rally driving friend took me out for a spin in the GrN Evo 6. After flicking the car, he pulled the hand brake hard, and the back end just said goodbye
With the ALS, it was one big drift around the hair pin
I say go for it. But it might be more expensive than what you think to get one fitted properly...
hey guys juz a enquiry abt handbrakes. does most or almost all handbrakes in cars use a diff brake system altogether with the wheel's brakes(lets sae both disc brakes on Front n Rear).
my friend argued tht all handbrakes use a totally independent DRUM brake system which is connected to the rear wheels....he said even if the back wheels r discs...the car's handbrake system would use a totally independent drum brake set....hence he assumed tht the handbrakes r VERY weak.i'm having a little doubt in his explanation....enlighten me plZ!
n one more.is the bimmer m3/m5 able to do the drifts easier than an EVO can due to the fact tht it's not AWD.....?? does an AWD system in a car lower the chances of drifting/skiddin on turns????
Guest
Posts: n/a
Well, you'll need to run an aeroquip hose from the master cylinder to the handbrake and from the handbrake to the rear brakes.
And yes, the normal handbrake works with a small drum. I guess virtually all cars are like that unless you change it...
yes espido1001, handbrakes work on a completely different setup. if you look closley at the rear wheels of a rear disc brake car you will see the drum on the axle as wheel.
also with drifting, drifting with a RWD car is very easy mainly for the fact your sole power goes to the rear wheels and to drift all you do is just add more power. although i would say an AWD drift is probabily a more controled drift mainly for the fact you have four wheels spinning and regaining control from too much oversteer in the drift is much easier then you could do in a RWD drift.
hello there... just wondering what brand is the hand brake? I am looking at one but would like to get a kit instead of having to go and get all the individual fittings. i have heard that there is a kit available in Japan....
Anyone help please???
Phillcom Rally.
Phillcom Rally.
vizi0n
10
Oct 6, 2017 04:08 PM
EvoRs
Mar 25, 2004 10:22 PM
