How do I remove front rotors?
Old Jun 23, 2004 | 04:42 PM
EVOQUICK's Avatar
Before buying new I will try to cut them first.
Warped- track used.
How much are new? - for the future.
Old Jun 23, 2004 | 10:04 PM
Yogi_B's Avatar
To remove the rotor you:
1) Unbolt the caliper, there are two bolts per caliper
2) remove the caliper
3) pull off the rotor
Its pretty easy to do.
I'm not sure how much new rotors are.
Old Jun 23, 2004 | 10:14 PM
oguratevo's Avatar
Warped- track used.
1.Remove the wheels. Remove the two pins holding the pads/retainer on each caliper(use a mallet and a drift tool for the pins).
2. Slide out the brake pads. Don't forget to buy a piston retractor to push your pistons back and might as well change your brake pads.
3. Clean all parts before re-assembly. Make sure you got all the parts(rotors and pads etc. ready).
4. Do the same steps on all the remaining brakes assuming your gonna change all for corners. Goodluck!
Old Jun 23, 2004 | 10:15 PM
oguratevo's Avatar
BTW, Next step is given by Yogi B.
Old Jun 23, 2004 | 10:23 PM
Yogi_B's Avatar
You don't have to remove the pads if you dont want to, I never do.
But you might have to push the pistons back into the caliper with a pad retractor, I always do, it makes putting the caliper back on easier.
Old Jun 24, 2004 | 06:19 AM
EVOQUICK's Avatar
Thank you
Old Jun 24, 2004 | 12:33 PM
EVOQUICK's Avatar
What kind of tool I need to unbolt a caliper?
I want to be ready before taking it apart.
Thanks
Old Jun 24, 2004 | 01:01 PM
Yogi_B's Avatar
To unbolt a caliper all you need is a 19mm socket with a wrench (or 19mm spanner if you want).
I find it helps to jack the whole front of the car up so you can pull the wheel over to make more room to work with as it gets a bit cramped down there.
cmiller10
Aug 23, 2014 07:40 PM
CaptainQuickie
Jan 14, 2011 03:07 PM
EVOKRAZY8
Oct 11, 2010 10:20 AM
philamthebest
Aug 6, 2010 01:36 PM
NismoSkylineGTR
Nov 3, 2002 01:08 AM
