Ohlins coilovers
Rif,
so the stage 1 & 2 comes with camber plates in the front and no pillow ball tops for the rear, and then the stage 3 comes with camber plates in the front and pillow tops for the rear ... correct?
I like the idea of getting 2 sets of springs, that would make the extra cost worth it to me.
Is the stage 3 coil overs too pricy for us 'normal' guys?
tia
tia
WORKS/Ohlins Stage III- Two sets of springs, front camber plates, and rear pillow ball mounts $2799.
Remember that SCCA, NASA, and SAE members qualify for a WORKS 5% discount (on non-sale items) year round! (That's $139.95 off!)
Originally Posted by steve_evo
Hey Rif,
Do you sell the camber plates for the front and rear individually? Who makes these for you?
Do you have pics of these?
Is it only camber adjustment or is there caster adjustment for the front?
Steve
Steve
We specifically developed these top mounts to fit the WORKS/Ohlins suspension. However, if you're interested in dialing in some more camber with the stock Evo suspension, we have another model that will fit that suspension as well.
The pricing for the stock version is $259 and $279 for the WORKS/Ohlins version.
Please feel free to email or call us at the shop if you have any additional questions.
Thanks for your interest,
Rifkin
sales@worksrally.com
415.641.9675
Originally Posted by wthoevo8
WORKS, are the spring sets make by Ohlins also? or they're other brands???
If you are intersted in any specific setup, email or call us and we'd be glad to figure out what would work best for you.
Thanks,
Rifkin
415.641.9675
Bumping an old thread. How often do the Ohlin shocks need to be rebuilt? I looked on their website and it should be inspected/serviced every 20-30km, which is roughly every 12-18k miles. Does this mean it needs to be rebuilt that often?
since this has been revived i will also ask a question. the springs on the stage 1 are for the r/t setup which is 4.4k/5.5k or 250/310? how much can u drop the back without needing the camber kit?
Earlier you mentioned having up to 10kg springs. Can your source stiffer springs then this? The set up I was looking at (GAB Prosso) has 12kg all around with daul springs. Anything like this possible from WORKS?
Originally Posted by Jamie@WORKS
A rebuild would depend a lot on what type of driving is being done with the car. A track-only car could need a rebuild in a few months whereas a daily-driver could go a few years. Inspection at the above interval would be a good idea and base the rebuild option on it.
Jamie,
Can the same rebuild times be applied towards the Zeals? I looked on their website and it said the shocks needed to be rebuilt every 12-15k miles. I can rack up 12-15k miles in half a year if I drove my EVO everyday. Also, what is the turn-around time for rebuilds?
TypeR31
May 2, 2016 06:20 PM
GSXRolla
Jan 31, 2008 08:12 PM
