Factory Boost Control VS upgraded boost assembly (pill)
Old Nov 24, 2008 | 02:28 PM
scheides's Avatar
EvoM Moderator
Bryan, you rock. Does the OEM boost control do direct boost control, or load-based boost control? Is there any way to spread the load out between the two BCS's, so you're not constantly at 100% ?
Old Nov 24, 2008 | 08:52 PM
NateDaJew's Avatar
subscribed. Thanks for the info.
Old Nov 24, 2008 | 09:26 PM
Boostd4's Avatar
As a testament to what this pill can do, Bryan installed the GST assembly in my car tonight. Prior to this new pill, my tune was dropping boost like crazy on the top end...it appeared to be a boost leak. In fact, it was a problematic stock boost assembly.
Once the new assembly was installed we picked up 25whp/20wtq (from the 1st tune) and were finally able to smooth out the curve. Excellent mod with great results. Final numbers were 305whp/305wtq with a K&N drop in and a GReddy Ti-C.
Old Nov 24, 2008 | 10:41 PM
RazorLab's Avatar
Load-target still even though the car has a 3bar MAP. I'm sure it's only a matter of time until the PSI-target mod comes along.
The two solenoids work off each other from what I have seen. Once you start messing with them you understand more.
Old Nov 25, 2008 | 07:28 AM
ThanatosG's Avatar
Wow, sounds pretty cool. I like the idea that it keeps an oem look, which is good for the dealership not saying "what warranty?"
Old Nov 25, 2008 | 08:35 AM
Red Dragon's Avatar
So basically it is the exact same boost assembly pill used in the Evo 8/9? Where can i get one? Will 3bar boost control solenoid have any effects with the pill? Is it better to run a pill or boost solenoid? Does the evo X run the same solenoid as the evo 8/9? Will an adjusted wastegate have any effects with the pill? Will a boost controller have any effects with the pill? The pill requires a tune right? I am a bit confused on how the pill works. How many stock pills are there?
Old Nov 25, 2008 | 10:46 AM
xbox4414's Avatar
Originally Posted by razorlab
It got a bit grumpy with more boost. It does only have a Drop-in filter after all.
It needs to breath more, which will come soon.
We will have pill and boost assembly on the site very soon.
Does this mean for those wanting to tune on our own we can pick up the boost assembly from you?
Old Nov 25, 2008 | 04:02 PM
RazorLab's Avatar
Originally Posted by gunzo
Do I dig out the original pill or replace the entire hose?
You replace the OEM pill on the pressure side.
Old Nov 25, 2008 | 04:04 PM
RazorLab's Avatar
Had another 10 in with the same mods as the Evo in the first post (HKS drop-in filter only)
Installed the upgraded assembly and went to tuning.
This one broke 300/300 which is quite an accomplishment on our mustang dyno with such few "mods"
301whp / 300wtq
+48whp / +32wtq peak gains
The HKS drop-in filter has shown to produce great power. 100% stock dynoed 234hp/258tq. Most powerful "almost stock" Evo 10 on our dyno yet.
+67whp / +42wtq over 100% stock
Old Nov 25, 2008 | 04:11 PM
xbox4414's Avatar
Bryan, you never answered if we can buy just the boost assembly from you for those who wanna self tune.
Old Nov 25, 2008 | 04:12 PM
RazorLab's Avatar
Yes it will be available just like it is for the 8/9.
Old Nov 25, 2008 | 05:49 PM
davidiii's Avatar
Where do i purchase? and when?
Old Nov 25, 2008 | 08:56 PM
BigmikeOC's Avatar
^^ +1
This pill sounds just like what the doctor ordered.
Old Nov 25, 2008 | 09:14 PM
MattyBoyMR's Avatar
+1 good thread...^_^
Old Nov 28, 2008 | 05:23 PM
SupremeX's Avatar
Looking forward to this pill. When and where will this be available? I am ready to order one now
