Factory Boost Control VS upgraded boost assembly (pill)
Old Mar 11, 2009 | 12:17 PM
  #136
pltek's Avatar
nevermind
Old Apr 5, 2009 | 10:53 PM
  #137
Project_Evo's Avatar
Would you say without the pill and not pushing the turbos limits you may run more reliable?
Old Apr 6, 2009 | 04:54 AM
  #138
pltek's Avatar
what is your wgdc% from 3000-5000 with the pill on both selonoids?
Originally Posted by razorlab
Updated first post with WGDC % data and some changes
Old Apr 6, 2009 | 10:17 AM
  #139
GST Motorsports's Avatar
It's up to the tuner on how he/she would like to tune the car.
Old Apr 6, 2009 | 11:36 AM
  #140
I unsersstand the tuner is going to feel more comfortable with one way or the other. And Im sure you guys do a great job tuning either way. I've had Mike tune a couple of my vehicles in the past and that guy is the best! Great customer service, and excellent tuning! But wouldnt your DD vehicle be more reliable without running the pill? Especially with our bad octane here in CA.
Old Apr 6, 2009 | 11:39 AM
  #141
Again, it's up to the tuner to determine what the car likes boost wise. One of the advantages to the boost pill is adding much more area under the curve in the mid range and upper mid range than the stock pill can allow, with the ability to taper boost how you like up top.
If everything is tuned correctly, I don't see why it wouldn't be any less reliable than stock.
Personally from tuning boosted 4 cylinders for over a decade on California's finest 91 oct, I've found that 91 oct is much more sensitive to ignition timing then boost.
Old Apr 13, 2009 | 03:24 PM
  #142
nj1266's Avatar
And that is the secret to tuning on low octane gas. If only other CA tuners followed the same methodology.
Old Apr 14, 2009 | 07:09 PM
  #143
Jblade's Avatar
Any updates on the availability of the entire upgraded Evo X boost assembly (versus just the pill)?
Old Apr 30, 2009 | 11:41 AM
  #144
andrewzaragoza's Avatar
any updates if you could use a gm 3 port to control the boost?
Old Apr 30, 2009 | 11:46 AM
  #145
Yes 3 port works fine. I tested the gruppe-s (PIERBURG) 3port on a 10 last weekend. Works great. The only thing you need to do on the 10 is shave off one part of the plug-play electrical connector for it to fit correctly
Will have more data soon...
- Bryan
Old Apr 30, 2009 | 12:33 PM
  #146
tonyboy's Avatar
- Bryan
great... thanks for the update.
Old Apr 30, 2009 | 03:33 PM
  #147
- Bryan
More info here:
https://www.evolutionm.net/forums/ev...-solenoid.html
daisaw1219
Jan 27, 2009 07:00 AM
mandy1
AEM EMS
Oct 29, 2008 01:56 PM
ExViTermini
AEM EMS
10
Feb 8, 2008 10:53 PM
Evo_Jay
13
Mar 16, 2006 11:55 AM
EVO8LTW
Aug 20, 2005 07:13 PM
