Factory Boost Control VS upgraded boost assembly (pill)
Old Feb 4, 2009 | 06:31 AM
  #91
YZRM1R6's Avatar
I really wish the aftermarket would do a "pill assembly and drop in filter" map... I don't want to turn my X into a rice rocket with exhaust and downpipes... I just want the car to be tuned the way it SHOULD have come from the factory while keeping it as stock as possible. (Make it a USDM FQ360 )
If such a map exists for the accessport will someone PLEASE direct me to it. And if it doesn't will someone out there PLEASE make one!
Old Feb 4, 2009 | 07:12 AM
  #92
gunzo's Avatar
I think GST is supporting their pill upgrade with ECUflash roms on request.. maybe they can chime in on this
Old Feb 4, 2009 | 07:25 AM
  #93
YZRM1R6's Avatar
AccessPORT compatability is the name of the game...
Old Feb 4, 2009 | 09:07 AM
  #94
awddyno's Avatar
flash
I don't think much people will be using accessport since the Ecuflash is now out for the Evo X.
About the wgdc, why not do a test with just increasing the gate pressure from 11 to 15 or so psi?
Old Feb 4, 2009 | 10:53 AM
  #95
KGHtheII's Avatar
Originally Posted by awddyno
I don't think much people will be using accessport since the Ecuflash is not out for the Evo X.
Wouldnt more people be using accessport if Ecuflash wasnt out for the Evo X? Regardless, Ecuflash is out for the Evo X: https://www.evolutionm.net/forums/ev...-released.html
Old Feb 4, 2009 | 11:03 AM
  #96
awddyno's Avatar
I meant now out, Fixed it
  #97
xbox4414's Avatar
He meant it's "now" out I'm guessing as he's been using it... Spelling error... I mean if you missed that that ECUFlash is out for the X that's kinda sad, LOL.
Old Feb 4, 2009 | 12:27 PM
  #98
aiden1983's Avatar
Really??? I wonder how much $$$. I should PM them
Old Feb 6, 2009 | 06:34 PM
  #99
nj1266's Avatar
Hey brian,
Care to share the BDEL settings that you used for your pill? If not, could you share the rough percent increase in BDEL settings that you used for the boost that was used?
Thanks
Old Feb 7, 2009 | 05:22 AM
  #100
Robevo RS's Avatar
how hard to install the boost pill?
Old Feb 7, 2009 | 12:19 PM
  #101
GST Motorsports's Avatar
1,000x easier than installing it on a 8/9.
All you need are:
short needle nose pliers
4-5" long phillips screwdriver or punch
Two hands
I'll write up a more informative how-to once I am back in town.
10mins tops. It's so easy I don't even charge to install it.
Old Feb 16, 2009 | 11:25 AM
  #102
linjy2's Avatar
All you need are:
Two hands
im confused on this boost pill. so for my cobb AP stage 2 i had to take a pill out. is this the same pill u guys replace? i just want to know which pill i need to replace, because i want to buy one and dont know which pill to swap out?
Old Feb 16, 2009 | 11:37 AM
  #103
I imagine you took the solenoid side pill out, which does increase boost 1-2psi or so peak and doesn't taper as much but that solenoid side pill is there for a reason.
We upgrade (replace) the pressure side pill, which is the pill in the hose off the T that goes to the compressor housing outlet (black pipe). We keep the other OEM pills intact.
Old Feb 16, 2009 | 11:38 AM
  #104
I imagine you took one of the solenoid side pill out, which does increase boost 1-2psi or so peak and doesn't taper as much but that solenoid side pill is there for a reason, which is to smooth the signal from the solenoid.
Old Feb 17, 2009 | 01:12 AM
  #105
sba's Avatar
sba
Hello Bryan,
Once when i was working on a rally IX group N, i was concerned about the destruction of the turbos in the rally environment - not from ALS - (here in Romania all the rally cars are using a 0.3 mm restrictor on the turbo side and that's all).
So i tested the metal pop-off valve.
And i made a rig to see at what pressure the pop-off is cracking open. So i found out that at exactly 1.5 bars, the pop off is opening.
The plastic one is opening at 1.2 bars.
So i changed that with a pop-off valve from HJS England which has a screw to set the preload. I set it up to crack open at 1.7 bars and the car had a better top-end and it kept more pressure after the peak.
After that i tried to incorporate this on a street car but where are some downside problems. When you drive the car normally, the car is stuttering because of the opening and closing very rapidly of the pop-off. So after 4 types of pop-off, i didn't found one that has the same neutral comportament like the oem one.
Maybe when you have time, you can check this on your dyno to see if there are some improvements of power and boost when using different pop-off.
