AMS EVO X makes 450whp on pump GAS!! Using our prototype 35R kit!!
Please explain your logic... if anything, the cast manifold has a greater ability to support more power/heat. Tubular = weaker. AMS are running their GT850R on this very cast manifold. I understand that it's not a T04 flange setup, but it should support well over 800 WHP.
But a side-mount, front-facing manifold would be something I'd want to buy if I ever go with a non-stock-frame turbo
If you aren't forced to use the stock location of the turbo there is quite a bit of space behind our engines to mount all but the largest turbo setups back there. The sidewinder setup doesn't look bad but I would imagine you would need to fab up some beefy brackets to hold a turbo out at that location. The clearance between the cooling system and ECU looks somewhat tight and having the exhaust side of the turbo (which can get glowing orange) right in front of the fuel and brake lines doesn't really sit well with me.
A casting turbo is always more reliable than a normal pipe welded manifold. Why does no manufacture built his cars with pipe welded manifolds? All manufacture does it with casting manifolds... Cast manifolds hold 100.000 of miles.
If the casting material is good I would prefer always a cast manifold !!
The way AMS did the construction is the best you can go @ the moment. A round V-Band solution on the manifold with connection the turbos carries the most air and best spooling.
That's also the reason TIAL brought the round V-Band exhaust housings to the GT-R Serie.
I'd take always the here showed AMS manifold. I'd just use another turbo !!
AMS------ GOOD JOB !!
Peter
Peter
yess it is
not true...honda k series turbo kits used side winders and they work in DD just fine
[/IMG]
