Dom2 on pump+meth = 200WHP over stock!
There's more in it still. Dom2 turbo seems to be the best turbo upgrade at this time - best bang for the buck even if it's still internally gated. Plus they're readily available unlike the Red.
Todd
I bought my dominator turbo from Buschur Racing but i would have bought it from tmarcel if he had been set up with blouch at the time.
He didn't exaclty loose 1000rpm of power. What he lost from 3.5k to 4.5k he gained from 7k to 8k. He did lose 1000rpm of spool though.
Just for comparison, David Buschur Dom2 car was able to produce 280lb.ft of torque at 3500rpm and 320 at 4000rpm, as compared to 200lb.ft and 250lb.ft respectively in the OP. DB's car is also running cosworth cams and no meth, plus full I/C piping and race core FMIC. Interestingly though, his car spooled better with the addition of the cosworth cams! I wonder if this will happen with this car too.
Congrats on the results
I think the FP Red, Dom2 and in extreme cases the GT30 bolt on's can have surge at lower RPM's when going WOT. Usually this surfaces in 5th gear but could happen in 4th if it is really trying to spool too fast with lots of volume. Cams let the engine breathe more and would allow it to pump more air at lower RPM's, as would a well designed intake manifold or proper headwork. High altitudes will make surge worse as would using an even larger compressor wheel.
not at all ive had it set at 8k since my car had 3000 mles on it and now it has 13,200 no worrys.Even my evo 8 and 9 i had set @8000 on stock head and cams and no problems.But i do change gears around 77k, 78k
You basically lost 1000rpm of power
