Dom2 + E85
Old Oct 21, 2009 | 07:20 AM
  #31
murlo26's Avatar
Originally Posted by HB Speed
yea i dont have a dynojet either thanks ......
My bad, I was trying to point out that difference in powers was probably different dyno related.
Old Oct 23, 2009 | 07:37 AM
  #32
Tractionlimit's Avatar
First of all, nice job GST! Great to see another big corn power X out there .
Originally Posted by awddyno
I can see that it spools earlier than the red.
To awddyno: I'm not sure how you can see this without a direct comparison between the two turbos on the same dyno. My Red spools better with E85 than it does with 93, granted this is higher boost too:
Old Oct 23, 2009 | 08:04 AM
  #33
murlo26's Avatar
Any update on this car yet?
Old Oct 23, 2009 | 08:18 AM
  #34
Are you refering to mine or his? I'm going on the dyno again a week from today.
Old Oct 23, 2009 | 08:42 AM
  #35
murlo26's Avatar
The one from GST in this case with the DOM2. They said they were getting ready to go for more power once they figured out their fueling issue, which I thought they did with a double pumper?
However I am interested in yours a lot as well
Did you change anything since last tune or you just going for a more ***** out tune?
Old Oct 23, 2009 | 10:08 AM
  #36
GST Motorsports's Avatar
Going back on the dyno very soon. BlaqOps progressive double pumper is in and AFR's drop to 10 from going out of control (up to 13AFR) up top before.
- Bryan
Old Oct 23, 2009 | 11:54 AM
  #37
Sweet, there's finally a double pumper out? I wanted that bad a few months ago... hope not to need it now.
Murlo- I removed the cat, ported the stock exhaust manifold and switched to AMS widemouth O2DP while I was at it. We'll also see if there's a benefit going from MBC to ECU boost. Sorry I couldn't test these individually for you, but cash & time limit.
Old Oct 23, 2009 | 11:55 AM
  #38
murlo26's Avatar
Nice, did you grab a 3 port too?
Old Oct 23, 2009 | 01:51 PM
  #39
I'm still unsure on that one. How much is it, and what exactly will it do for me?
Old Oct 23, 2009 | 02:35 PM
  #40
murlo26's Avatar
It's $100 at the most, I have the perrin one, it works great.
It will give you a lot better control over your boost allowing you to more precisely control when the wastegate opens and closes. You should have better midrange power and should allow you to hold a few more psi up top
It is easily worth $100.
Old Oct 23, 2009 | 06:29 PM
  #41
Cool thanks. I'm doing some research on the GM and Grimmspeed (similar to Perrin). Hard to say which is better. Also, seeing that my MBC is cranked all the way down, will this really have much benefit?
Old Oct 24, 2009 | 03:47 PM
  #42
Stormtrooper's Avatar
looking forward to these results =D
Old Nov 1, 2009 | 05:14 PM
  #43
murlo26's Avatar
Any info on this car or more importantly the progressive double pumper from blaqops? I couldn't find any info on the google machine about them, just linked to a few threads on EvoM and you don't list them on your site GST.
I am going to need a good amount more fuel here soon GST I was going to buy a new fuel pump kit too but I don't want to because I assume the blaqops one will take care of it.
Old Nov 1, 2009 | 10:35 PM
  #44
Send me a PM.
- Bryan
Old Nov 3, 2009 | 04:17 PM
  #45
More info on Blaqops:
http://www.blaqops.com/products.html
