2010 Stock Dyno numbers.
Old Nov 29, 2009 | 05:23 PM
Phantom X Evo's Avatar
Hey,
Just got back from Hot Import What? and had the car on the dyno for a baseline.
240Hp and ~262Lb-ft on Mase Engineering's Dyno Dynamics.
Old Nov 29, 2009 | 05:28 PM
08EVOVA's Avatar
nice numbers!! when will you start the mods?
Old Nov 29, 2009 | 05:45 PM
Noize's Avatar
EvoM Administrator
What correction factor does Mase use?
Old Nov 29, 2009 | 05:54 PM
Mike Bones's Avatar
Seems as if the max tourque rated at 4000 rpm is incorrect from the factory.
Old Nov 29, 2009 | 06:01 PM
Clark_Kent's Avatar
Factory doesn't use a chassis dyno. Either way, it doesn't quite work like that.
Old Nov 29, 2009 | 06:05 PM
Not sure of the corr factor.
ETS intake and AMS DP are being shipped. Still less than 1000mi on the car.
Old Nov 29, 2009 | 06:06 PM
jrsimon27's Avatar
what did a stock evo x 2008 model do on this dyno?
Old Nov 29, 2009 | 06:40 PM
EvoX2NR's Avatar
looking on another site, they dyno about the same... the torque curve is a little different but the same numbers are still hit
Old Nov 29, 2009 | 08:51 PM
Noize's Avatar
EvoM Administrator
I've never before paid close attention to a Mase graph, but have lots of hours on a Dyno Dynamics. Whatever he's using for the tach pickup or gearing value is weird, or he is using a wonky ramp rate, or both.
Unless he aborted the run 1000rpm before the rev limiter, everything is phase shifted to the left. That would artifically inflate the torque, because a Dyno Dynamics measures work (HP), and extrapolates the torque from a simple equation. This will not change peak whp values, though.
I also think he has a 10-12% correction factor on top of all that.
Doesn't matter, its only a tuning tool, but its hard to make sense of it the way it reads now.
Old Nov 29, 2009 | 09:16 PM
DG Motors's Avatar
I'm with you on this since I own a dyno dynamics. Roller speed was most likely used for the graphing of this pull since the run is cut short 1,000rpm.
We always use roller speed and an evo x gsr needs 4,250rpm @ 60mph to graph correctly.
I am also going to assume the correction factor is boosted up since a bone stock 08/09 evo x gsr will consistently make 195-205whp on a 1.0 CF on our dyno.
If this newer 2010 is making 240whp on a 1.0CF then we are looking at a nice boost in power from the earlier models!
Thanks for the information!
Old Dec 1, 2009 | 12:34 AM
nj1266's Avatar
Mitsubishi enabled lean spool on the 2010 models. So even though the target AFR map is the same as the later roms of the 2008 model year, then car logs leaner AFRs than the 2008 models. I have verified this by tuning a 2010 Evo 10 this past Sunday. It logged leaner on the stock rom than 2008 cars on stock roms with similar mods.
Old Dec 1, 2009 | 07:15 AM
jrsimon27's Avatar
so if i have a 2008 model how can i enabled lean spool in the ecu?
Old Dec 1, 2009 | 07:55 AM
mike100's Avatar
If you're gonna void the warranty, just go for broke and and fully tune it.
Old Dec 1, 2009 | 10:45 AM
GST Motorsports's Avatar
Moore Auto
Evo X Dyno Results
Jul 4, 2015 01:34 AM
4g63girl
Mar 23, 2010 10:26 PM
cpunlamd
Evo X Dyno Results
65
Feb 25, 2010 08:04 PM
pstl_pete
Evo X Dyno Results
17
Jan 28, 2010 05:18 PM
Fast_Freddie
Jan 19, 2010 01:59 PM
