CBRD BBX lite- cbrd fmic and ic pipes
Old Nov 23, 2010 | 04:39 AM
  #31
MicMcKee's Avatar
It's nice to see the baseline is pretty comparable to my car as it sits now...
Though I think this might solidify that I want the BBX as opposed to the lite,
1000cc injectors, did you upgrade the fuel-pump as well?
Good work as usual,
Cheers!
Old Nov 23, 2010 | 09:39 AM
  #32
CBRD's Avatar
Originally Posted by AWD Motorsports
405whp on the MD is pretty solid for this turbo.. Your dyno and Buschur MD read pretty close i think you told me and maybe yours slightly lower right??
Mike
Mike,
our dyno seems to read pretty similar to davids. He will confirm this for you.
cb
Old Nov 23, 2010 | 09:41 AM
  #33
CBRD's Avatar
Originally Posted by anasmak11
But y the exhaust manifold? it could be netting you 20-30whp. But losing the spool at the same time, which is the exact opposite reason y someone would buy this turbo..
the manifold doesnt really affect spool too greatly... a 20% change in humidity affects it more
this car made 405 on the stock intake as mentioned, it now has a 3" CBRD cold air intake, and will be retuned shortly, I expect it will pick up another 20whp!
cb
Old Nov 23, 2010 | 09:43 AM
  #34
AWD Motorsports's Avatar
Originally Posted by CBRD
Mike,
cb
I found the info after.. You said " david's own evo X made 306whp, and made 287 whp here ".. Thanks..
Old Nov 24, 2010 | 12:42 AM
  #35
anasmak11's Avatar
Are there any pictures or details on the cold air intake?
Old Nov 26, 2010 | 10:46 PM
  #36
lakay888's Avatar
I want to see too
Old Dec 3, 2010 | 08:06 PM
  #37
apexsilverbbx's Avatar
Old Dec 4, 2010 | 08:09 AM
  #38
evoxsi's Avatar
Originally Posted by apexsilverbbx
bout time u learn how to post haha
Old Dec 4, 2010 | 10:47 AM
  #39
WREvo's Avatar
CBRD turbo's ftw man. 405 with a stock intake.
Old Dec 4, 2010 | 11:03 AM
  #40
details on the intake- 2 piece 3 inch aluminum intake piping with a velocity stack/filter combo ingesting the cold air.
I am very pleased with the intake.
Old Dec 4, 2010 | 03:02 PM
  #41
JEP's Avatar
JEP
A previous ? was asked concerning the difference in power output of the bbx line of turbos vs forced performance's line of turbos. Could Chad or one of the other venders answer this with more detail. Thanks...
Old Dec 5, 2010 | 12:18 AM
  #42
anasmak11's Avatar
new results with the intake?
Old Dec 9, 2010 | 06:42 AM
  #43
Peter10654's Avatar
WTF... !! The BBX lite seems to be a really great turbo for stock engine !!
Old Dec 9, 2010 | 07:11 AM
  #44
Final numbers at CBRD were 411whp/349lbft at 26psi after intake install/tune. I also had Cbrd modify my buschur crossflow exhaust by installing an 18 inch resonator while the intake was being built.
Old Dec 9, 2010 | 07:36 AM
  #45
Peter10654's Avatar
That's really great numbers !!! I'll think about this turbo
Peter
