2008 Evo MR + FPred + E70 + 5000ft elevation
Old May 8, 2011 | 05:33 PM
RazorLab's Avatar
Interweb tuned this built 2.0L located in Colorado Springs.
5000ft elevation so I'm showing normal interweb VD "dynojet" and also the "cool hip" 1.18 correction that all the shops seem to like to use in Colorado so other Colorado evo owners can compare better.
Tune isn't 100% done yet but this is where it currently is. The car is basically ran out of fuel system with more boost (maxed IDC) so I turned the boost down.
Boost is currently peak 28.5 psi peak and drops to about 20psi at 7800 rpm. Mile high elevation is not a turbos friend.
2008 Evo MR
DW 1000CC injectors
Blaqops single fuel pump
3.5" Primo intake
Buschur UICP
Buschur 4" Intercooler
Test pipe
Buschur 3" Quiet exhaust
MAP ceramic coated downpipe
Synapse BOV
Ported Red w/ anti-surge + 18psi WG
Built 2.0L with:
OEM size Wiseco Pistons/MAP X rods
ARP rods/studs
ACL bearings
STOCK cams/crank
3port boost solenoid
Stock ECU tuned via Ecuflash
Stock SST clutches
E70 fuel
1.18 correction:
Log so people can see the room left with the 3.5" MAF:
Old May 8, 2011 | 08:55 PM
dcpatters's Avatar
Pulling like a freight train. How's the SST shifting with the stock clutches and new power?
How long did it take to tune remotely?
Old May 11, 2011 | 04:48 AM
Griffin5's Avatar
Originally Posted by razorlab
Interweb tuned this built 2.0L located in Colorado Springs...
Hi Bryan, you have PM.
Old May 11, 2011 | 02:02 PM
Mendo's Avatar
nice!
Old May 11, 2011 | 03:36 PM
Optiblue's Avatar
Wow, stock clutches are still holding well into the 400's!
Old May 13, 2011 | 02:36 PM
josh08gsr's Avatar
e85 is the best!!
josh08gsr's Avatar
nice #'s
Old Jun 22, 2011 | 11:50 AM
cweav's Avatar
Sweeeet!
Old Jun 22, 2011 | 02:44 PM
NGK_EVO's Avatar
Nice #'s. I am curious how long the SST will hold close to 500.
Old Jun 22, 2011 | 09:07 PM
project_skyline's Avatar
Very nice!
If you run a 1.0 CF(413whp) then you can tell the person it would read inline with harvey's DD in longmount.
Old Jun 28, 2011 | 07:49 PM
symple84's Avatar
Pardon the newb question but what is FP Red??
Old Jun 29, 2011 | 04:50 AM
tkromer's Avatar
Forced Performance "Red" model turbo. It's an upgraded turbo...
razorlab
5165
Aug 11, 2024 07:56 PM
GST Motorsports
Aug 4, 2023 04:34 PM
razorlab
Sep 14, 2019 07:23 AM
GST Motorsports
Evo X Dyno Results
16
Dec 16, 2009 09:01 PM
razorlab
Dec 2, 2006 07:46 AM
