Mil-Spec ported throttle body 14 hp gain
No, I'm pushing 466/424 before the tb on E85. Calvin at Cobb thinks it would hit 480 maybe 485 hp and as much as 440 tq. It's a guaranteed rod break on the dyno. Once the motor is built we'll redyno it.
To prove exactly how much of a power increase a part gives you, you need to first off not touch the tune. Then you need to to dyno the car on the same day at pretty much the same time with the stock part on then dyno it again with the new part. Try to keep all variables (weather conditions, strap tensions, etc...) the same.
you may have a point in the variables and all (weather stuff), but in the end his setup gained whp which is what he proved, plus he did mention that he had im, etc port matched.
Also, boost pressure (psi) does not tell you exactly how much air is going into your cylinders. You have to have a restriction to have boost pressure. So say you installed a ported head (with different valves, springs, etc) and when you dyno'd it your boost pressure dropped alil compared to when you had the stock head installed. This does not mean you have less air going into your motor, it means your head is more free flowing and less restrictive.
to OP, nice gains.
Every time I do any mod at all, I get a re tune no matter how small or minor.
Freebs
Evo X Dyno Results
13
May 4, 2015 07:47 PM
Kracka
12
May 13, 2013 03:58 AM
Kracka
Evo X Dyno Results
295
Oct 3, 2012 03:03 PM
