2.4L 3586hta 93 Pump
Old Jan 8, 2013 | 09:30 AM
RU EVO's Avatar
The car has come a long way and seen many changes. Right now just enjoying the 93 pump tune until we up the boost and run the E85. Car spools amazingly fast. It has a power band similar if not better than FP red on a 2.0L. The overlay below compares my setup with a FP Red on 93 pump and 2.0L. The feel of the turbo on the street is eerily similar to the stock turbo and the tq punch is everywhere. Its the perfect street car.
-93Pump 3rd Gear Pull Conservative Tune
Old Jan 8, 2013 | 10:11 AM
thiagobr03's Avatar
Realnice numbers, however, seems to be a little inflation at the end where tq and hp goes up no? Was that a real smooth road? Looks good man enjoy it
Old Jan 8, 2013 | 11:23 AM
RU EVO's Avatar
Yes it was a smooth flat road. Countless pulls were done yielding the same results.
Old Jan 8, 2013 | 11:50 AM
vegittoss15's Avatar
I thought I recognized this car. Turbo's all good now?
Old Jan 8, 2013 | 12:07 PM
RU EVO's Avatar
Hopefully yes. We put an inline filter in the feed line and have to monitor it week to week initially. I would like to get the e85 tune in the next month.
Old Jan 8, 2013 | 12:08 PM
Wait, so did you send it back after it seized or did it just start working?
Old Jan 8, 2013 | 12:54 PM
RU EVO's Avatar
Had to send it back for repair. It took about a month. I got the car back last Saturday.
Old Jan 8, 2013 | 01:10 PM
Ouch. I should be getting mine back soon too, hopefully.
Old Jan 8, 2013 | 02:55 PM
Spazpilot's Avatar
Looks like your Evo is sitting in some Romanian Chop Shop! Stop loving your Evo! Great numbers
Old Jan 8, 2013 | 03:31 PM
tscompusa's Avatar
post graph with smoothing 0 then 6
i think the graph is inflated at the end from my experience using vd on
hundreds of cars.
heres an example using your graph:
when you have hp and tq randomly skyrocket up at the end yet the boost line stays the same
thats a good sign somethings not legit with vd.
i don't think its gonna make over 580 on a dynojet based on the graph posted.
heres an example same car. no change in nothing. same inflation at the end like your graph,
but not as drastically effected throughout the rpm range:
this same pull with a smoothing of 2 looks normal.
you could hide the inflated and nobody would ever know. but from smoothing 1 to 6 theres a 50whp decline which
is a red flag for an inflated graph. you shouldn't have more then a 8-10whp difference from smoothing 1 to 6.
you definitely have some inflation going on. even at smoothing 2 yours is pretty noticeable. either way your numbers are strong for 93. 700~ shouldn't be a problem on e85.
Old Jan 9, 2013 | 07:43 AM
murlo26's Avatar
I don't know that I would say this is "stock like spool" but it does look pretty awesome.
Need to rev that ***** out moar!
In for E85 numbers, but beast numbers on 93. Good work dino too.
Old Jan 10, 2013 | 10:02 AM
rrkpitt15's Avatar
Nice setup but this doesnt "out spool" a red. I am hitting over 20psi with my jb red at 4k rpm.
Nice setup though.
Old Jan 10, 2013 | 10:19 AM
This pull was also started at 3500. I wonder what the chart will look like starting lower.
Old Jan 10, 2013 | 01:15 PM
acidtonic's Avatar
This.
If we're talking about spool, please start the pull earlier.
Old Jan 10, 2013 | 07:23 PM
RU EVO's Avatar
Nice setup though.
I will try to get the overlay from my tuner where we compared. It was a red he tuned as well.
