320whp with full bolt ons on e85..
Old Jul 8, 2015 | 07:44 AM
Perplex's Avatar
I feel like this is low? Should I take the car to get tuned somewhere else or what? The car was street tuned by a smaller shop a ton of people recommended me to.
I got ets uicp, air intake, test pipe, downpipe, catback, dw fuel pump, I'd 1000cc injectors and tuned on e85. I thought I would be a lot closed to 380 or so. Car is a 2011 MR.
Edit: also a gm 3-port.
Old Jul 8, 2015 | 08:52 AM
MisterRegato's Avatar
MR cars dyno lower than GSR by a decent bit could be that, and could be a mustang dyno reading lower than dyno jets
Old Jul 8, 2015 | 08:57 AM
e_kobz's Avatar
These numbers are pretty low, assuming you're using virtual dyno. I did 330whp on crappy AZ 91 via the VD and confirmed on a DJ. A buddy of mine has a Evo X MR with full AMS bolt-ons, ID1000's, a DW265c on E85 and he did 365whp on a DJ. I'd say take it to another shop
Old Jul 8, 2015 | 09:11 AM
Perplex's Avatar
This was all done on a vd and street tuned. I don't know whether I should call the shop and try to talk to them about it, but like I said this seems really low for my mods.
Old Jul 8, 2015 | 09:54 AM
JrEvoXnitez's Avatar
Thats low for mods AND e85. Im bone stock with tune and have 330 both ways…..
Old Jul 8, 2015 | 09:57 AM
yifuqiao's Avatar
Could this be that Road Tune is so conservative cuz it is done in a non-controlled environment?
Old Jul 8, 2015 | 10:04 AM
Perplex's Avatar
So did I just waste $400 on tuning? The place I took it to is 5 hour round trip so I can't easily take my car back.
Old Jul 8, 2015 | 10:07 AM
e_kobz's Avatar
How many pounds of boost was your car tuned on?
Old Jul 8, 2015 | 10:11 AM
Perplex's Avatar
24 I'm pretty sure.
Old Jul 8, 2015 | 10:19 AM
e_kobz's Avatar
Originally Posted by Perplex
24 I'm pretty sure.
There's your problem. The whole reason people run E85 is because it burns slow and cool. It allows for more boost and more timing. On E85 you can get away with 28psi no problem. Some guys have even ran 30psi. Not advocating this by any means. But you should at least be able to run 28psi safely with 0 knock. Crank it up to 28 and there's your 360whp. 24psi is pump gas boost
Old Jul 8, 2015 | 10:24 AM
Take it to a different tuner
Old Jul 8, 2015 | 02:07 PM
obake214's Avatar
Yeah different tuner for sure.. I have bolt ons with pump gas which my base run I was at 330hp/346tq which plugs fouled out so am going to get it retuned today.
Old Jul 8, 2015 | 05:13 PM
roni4g63's Avatar
although 320 does seem like a low number for your mods on e85, did you take into consideration the weather? it's been pretty warm lately and that affects numbers since the hotter the air the less dense it is. same thing with humid weather. also those are not full bolt ons since you did not mention licp and an o2 housing and an aftermarket ic, which actually helps, I believe it is still pretty low, I also heard that road tuning can show about 5% less of what the car makes, correct me if im wrong on that. but yeah, id talk to another tuner and see what they think. goodluck
Old Jul 8, 2015 | 06:05 PM
backwoodsRUNNER's Avatar
I was at 316whp, but for longevity sake, got the boost dialed back about 2lbs and dropped to 300whp. Given that I was getting close to 320whp on 93oct and no HFC...I'd say you should be higher
EVOIXreno
May 1, 2013 11:21 PM
tscompusa2
Dec 22, 2012 04:40 AM
Beebo05
Sep 2, 2012 02:16 PM
Nelson999
Nov 24, 2011 07:06 PM
Bramage_Dained
Aug 2, 2011 09:35 AM
