The official "prosport gauges" thread
My premium boost gauge ever since ive had it, pegs out relatively easy. Im tuned to only 23.8 but i have no problems hitting 30 as per the gauge 10 times out of town. Anyone elses do that?
Well that does not sound like a gauge problem mine is tuned at 25psi and I have my warning at 28psi i rarely hear it
i have the peak warning guages and the noise on startup is starting to get really old.... is there any way to disable this? or what about the evo series they are pretty cheap is it worth it for me to buy them? and the wideband is it accurate? i have an AEM but the harness is like pig tailed together so im looking for a new one
hey prosport
forgot to mention something about my problem with the flickering fuel press gauge. its daisy chained into the oil pressure gauge. the oil pressure gauge stays fine at all times but the fuel pressure is still flickering. is it possible that power isnt being delivered to the fuel gauge under WOT?
i have been to busy to redo wiring lately but now i dont think its the wiring at all since the oil press gauge works just fine. any ideas?
Would there be any issue with running a peak/warning boost gauge, and the regular premium series oil pressure and oil temp gauges? Would they look/act similar on the start up? I dont have a need for peak or warning on those other two gauges... Thanks alot
To clarify... One premium boost ad two other performance series
So while it is possible we do not recommend it.
Any videos of the opening ceremony on the Evo series, and any idea when they'll be back in stock? I've had Premium series boost and oil pressure gauges for about 4 years, and I've maxed out the boost gauge so I'm considering a switch. I think I remember reading the Premium harness won't work on the Evo so I'll need to change out the connectors. Are my current boost and oil pressure sensors compatible with the Evo series? Sorry if this has already been answered. I scanned over the last couple pages but didn't see it.
Bummer... I was hoping the ceremonies would match. Thank you for answering so quickly
