Back Up Camera
Old Jun 2, 2009 | 11:20 AM
  #76
raptor1028's Avatar
Originally Posted by 5harkology
I just installed an ebay camera on my MR (factory MMCS).
The install went quicker and smoother than I expected. Fishing the wire was pretty simple, only tricky part was getting the interior door sill trim back in and lined up correctly.
There is not much documentation on where to pentrate through to the license plate area so I will comment on what I did.... I drilled a 1" hole behind the trunk plastic latch trim piece (right below the dentent on the sheet metal). This worked out perfectly! It lined up directly with the existing hole above the license plate. I then just fished the wire under the LR passanger seat.
Total cost: ~$50 (ebay camera= $30, adapter= $20)
Total install time: 3.5 hours
I will try and get some pics up soon.
Do you have a link to the type of camera it was? How is the video quality? Is it choppy? Thanks
Old Jun 2, 2009 | 02:06 PM
  #77
demonclaws's Avatar
here is the link for cheap backup camera : http://stores.shop.ebay.ca/invinas__...&submit=Search
Old Jun 2, 2009 | 06:26 PM
  #78
5harkology's Avatar
http://cgi.ebay.com/NEW-CAR-REAR-VIE...3A1%7C294%3A50
That is the exact camera I purchased.
Video quality is OK. It's not great, but nothing worse than I expected. Nightvision is basically B/W. The main problem is when it's raining, moisture will block the lense sometimes.
Old Jun 3, 2009 | 12:14 AM
  #79
c_reber's Avatar
Thats about the same one I got. As mentioned, the video quality is good, but not great vivid colors (I guess I"m used to my 73" DLP home TV in HD).
Rain? What's that? LOL, luckily I live in a desert, so haven't had the moisture problem yet.
Old Jun 3, 2009 | 12:31 AM
  #80
salukidude's Avatar
^ Yeah I hear what you're saying on the quality! I guess my pad is not as loaded as yours, I'm just looking at a 36' LG
Mine gets a little blurry when it rains; like once every 3 months. My nightvision is pretty good and in color. The reverse lights really help out. [Daytime pics on page 2]
Old Jun 5, 2009 | 04:49 PM
  #81
reggiesd's Avatar
my nissan armada has the factory nav and back up camera and when it rains it still gets all wet and smudgy so you can't see anything either..so i'm gonna say it doesn't matter if you buy the cheap ones or the high dollar cameras
Old Jul 27, 2009 | 06:50 PM
  #82
reggiesd's Avatar
hey fellas..can anyone help me out? i tried to install my back up cam today to the factory nav and the write up here: http://www.soflancer.com/downloads/backcam.pdf says "On the back of the NAV you will find on the right side there is a 12 pin
connection block with nothing connected. Keep this pin out in mind. "
well there was something plugged in there thati had to unlplug...i plugged the harness and the rca cable in and try to set up the cam and it won't show anything on my screen (just black).
here's the back of the nav unit and something's plugged in there...
Old Jul 28, 2009 | 11:51 AM
  #83
geezevox's Avatar
I pulled my radio out last night to install a back up camera, and got the same configuration. What about the s-video at the top? Is that an output, or an input?
Old Jul 28, 2009 | 01:21 PM
  #84
AisuShiden's Avatar
Wow, great info. I might have to do this to the 3000GT...
Old Jul 28, 2009 | 01:25 PM
  #85
N1MR0D's Avatar
Looks really clean!
Old Jul 30, 2009 | 04:27 AM
  #86
Spunkysandoval's Avatar
I just got my camera in the mail yesterday. I'm going to install it tomorrow
Old Jul 30, 2009 | 09:18 AM
  #87
beetle_orange's Avatar
reggiesd, i was just looking at an old picture of the back of my nav and it looks exacatly like yours. i wonder now how the people with the MMCS are doing it since there is a plug in there and it seems you cant remove it. do you think you can just "tap" onto the wires?
Old Jul 30, 2009 | 01:55 PM
  #88
reggiesd's Avatar
there's a pdf on the how to install of a factory mitsubishi back up cam...and it says there that if there is something plugged in to that spot you simply just unplug that and zip tie it to secure it with the rest of the cables...then you plug in the mitsubishi back up camera wire harness(which i did not have)...the aftermarket harness i had didn't work though...i'm not so sure why.
Old Jul 30, 2009 | 02:04 PM
  #89
EvoCop's Avatar
Got any pics!!
Got any pics of what it looks like from inside the car?
Old Jul 30, 2009 | 03:48 PM
  #90
https://www.evolutionm.net/forums/sa...tion-unit.html
look at this guy's nav its blank. i am confused now.
