Radio not working after gauge install!!
Old Jun 20, 2010 | 04:03 AM
cpunlamd's Avatar
I have a Pioneer Avic Z110bt installed in my 2010 Evo X. Everything was running fine until I tapped into the accessory wire to power my boost gauge. (FYI: I also have a Mito-2 that retains the factory RF system) Im thinking the problem is:
1. I burnt the radio fuse
2. The Mito-2 that is wired in is toast
Can anyone tell me where the radio fuses are located? Are there more than 1 fuse??
Old Jun 20, 2010 | 04:05 AM
cpunlamd's Avatar
I forgot to add. Since the radio is no longer getting power, the boost gauge that I tapped into the accessory wire doesnt get power either.
Old Jun 20, 2010 | 06:25 PM
cpunlamd's Avatar
Ok. Found out that the Bussman fuse taps I used for the other gauges were causing the problems. I ran 2 Bussman fuse taps under the kick panel. I only used 1 fuse when I supposed to use 2. Somehow, even though I didnt tap the radio fuse, it still caused the loss of power to the radio. Not sure how that happened since I tapped the side view mirror fuse, but it did. Once I clipped in the additional fuse, everything was powered up..
delliott00
Jan 26, 2017 01:43 PM
akaOtherWise
Feb 17, 2016 04:58 AM
WHITJCT
Jul 24, 2015 12:32 PM
FoxFMX
Jul 9, 2015 05:03 AM
alexgaspari
Lancer How Tos / Installations
Apr 16, 2014 08:42 AM
