Is this a good Ground? Hearing a louder buzz in the radio speakers
This is an evo 8. I posted here cause I need advice from a more active section of the forum, hince the evo x section.
I did a battery relocation to the trunk on my evo 8. I bought the car with a crappy radio from the previous owner and the radio speakers already have a slight buzz/whine to it.
After the battery relocation, I am hearing a significant louder buzz to it.
The question is. Is this a good place for a ground? Is this a good ground?
Yes I did shave off the paint where i bolted the wire. I did not solder. I simply pinched the wires really tightly.
Looks good to me, but how far is it from the battery? You want to keep that distance as short as possible.
Is is a buzz or a whine? Increase with acceleration?
If it's just a buzz your amp's gain may be set too high. Essentially it's amplifying nothing, causing the buzz.
it is a whine. and it increases with rpm. The ground wire is 12inches away from the battery.
The whine will be gone as soon as i turn off the radio. Then it is just pure good engine sound.
Alternator whine. Check this thread, post #42 specifically:
https://www.evolutionm.net/forums/ev...peakers-3.html
All I have to say is good luck. I've had reoccuring problems since I pulled my stock unit. I've gone over every inch of the system and had multiple shops look at it too.
johnnnyjeans
For Sale - Wheels / Tires
Apr 23, 2014 09:04 AM
johnnnyjeans
Mar 31, 2014 08:22 AM
johnnnyjeans
May 6, 2013 01:10 PM
johnnnyjeans
Jan 20, 2013 06:08 PM
