iPhone 5 iOS6 will not connect to USB?
Old Nov 6, 2012 | 08:49 AM
Shadow's Avatar
I have an evo X with the SSS and since I got an iPhone 5 with iOS 6 my phone will not connect to USB. I've given it 30 mins and it still will not load and play. Has anyone else had this issue? Is there a firmware update for the head unit?
Old Nov 6, 2012 | 09:01 AM
vegittoss15's Avatar
I don't think iOS6 is compatible. In fact, I can't even find the iphone5 on there.
Old Nov 6, 2012 | 09:08 AM
Shadow's Avatar
I just spoke with cousin who has an iPhone 4S with iOS 6 and his works fine. Which leads me to believe it is either the 5 itself or the new lightning connector
Old Nov 6, 2012 | 11:45 AM
Buru_EvoX's Avatar
Can you play music via bluetooth? That's what i do with my 4S.
Old Nov 6, 2012 | 11:47 AM
Shadow's Avatar
Yeah I can and that's what I usually do but sometimes I need to charge my phone. My evo doesn't seem to like if I have it plugged in to the car and paying through bluetooth. It will randomly pause my music.
Old Nov 6, 2012 | 12:30 PM
Buru_EvoX's Avatar
I bought a USB car charger in case I need to charge my phone. Sorry about the bluetooth pausing on you. While on oS 5, the music data wouldn't update, but that was fixed for me in 5.0.1 and 6.0
Old Nov 6, 2012 | 12:32 PM
Shadow's Avatar
Yeah it's not the OS I believe its the actual iPhone 5 or new USB cable. I know I can buy a USB charger but that defeats the purpose of having USB built into the car.
Old Nov 8, 2012 | 07:43 AM
Gozen's Avatar
When you check the Mitsubishi Fuse website, the iPhone 5 does not even appear on the list to check if the device is compatible yet. If I had to guess, as previously mentioned, this has to do with the new lightning to USB cable.
There is some slight home that Mitsubishi may release an update/new software version for Fuse to allow full compatibility. Based on the past release schedule, this may not happen until June 2013. http://www.mitsubishifuse.com/support.taf?p=7&n=1
I am not sure if a lightning to 30 pin adapter would correct the issue but if an adapter is available it would be worth a shot trying.
Old Nov 8, 2012 | 10:58 AM
AWDTerror's Avatar
It's the cable and the way that the pins are assigned on the cable. The lightning cable has an authentication chip inside of it that assigns what each pin needs to do. As such if your car hasn't been updated to support this then you won't have audio or video out. I have an aftermarket headunit and they just update the firmware to support this and it works just fine now, but didn't before.
The adapter may work, but it only supports analog out. It's worth a shot trying it. You can always return it if it doesn't work.
Old Nov 8, 2012 | 11:23 AM
menasor's Avatar
I plug it into the USB port to charge, and I stream audio through bluetooth. Works in my car
Old Nov 18, 2012 | 02:08 PM
Pitbull1981's Avatar
Good to know. I'm due for an upgrade soon and want an iPhone 5.
Old Dec 4, 2012 | 10:05 AM
titleistforged's Avatar
If this helps, I have a 2013 GSR with the RF package, and I was able to hook up my iPhone 5 with iOS 6 via both BT and USB. Zero issues. I did have to go buy a new Lightning cable from the Apple store, obviously.
Old Dec 4, 2012 | 10:09 AM
stryderlis's Avatar
Iphone 5 works on my 2012 X base MR via USB and BT.
Old Sep 7, 2013 | 02:50 AM
ctadashi's Avatar
does anyone know how much the update is from mitsubishi or if its online anywhere for free?
I have a 2011 evo x that hasn't been upgraded and I just got an iphone 5.
8three
Lancer Troubleshooting
Jun 20, 2016 12:12 PM
ChrisBird317
Apr 10, 2016 04:13 AM
FASTER345
Feb 18, 2015 08:08 AM
Bike Mech
Feb 1, 2015 08:15 PM
JohnnyTSi
Jul 19, 2012 12:18 PM
