help with stock rockford sub installation
Old Aug 21, 2013 | 04:27 PM
rcheung's Avatar
I recently bought a used stock trunk rockford subwoofer. It comes with four speaker wires and each pair plays the sub. Do all four wires have to be hooked up to my amp or can i just use two, will it make a difference?
Old Aug 21, 2013 | 05:39 PM
gonzo082's Avatar
Im doing the same thing with my system. If i read everything correctly since it is a dual coil sub you can connect your sub in series or parallel, depending on the sound you are looking for, and i also believe the sub is 75 watts rms.
Old Aug 21, 2013 | 08:36 PM
ikt's Avatar
ikt
each pair is one voice coil. each coil is 2ohms. The easiest install is to get a stereo ampllifier and run ones set of wires to L and one to R
Old Aug 22, 2013 | 06:00 AM
rcheung's Avatar
Does anyone know which color wires are to which voice coil and which are the + and - to each?
Old Aug 22, 2013 | 06:01 AM
sirsleepsalot's Avatar
Originally Posted by ikt
each pair is one voice coil. each coil is 2ohms. The easiest install is to get a stereo amplifier and run ones set of wires to L and one to R
Each coil is ONE ohm !
Plugging them in parallel will result in a half ohm load. In series will result in 2ohms. Most likely, your best bet will be to use a small Class D amplifier that is 2ohms stable. (something around 300W will be plenty).
Old Aug 22, 2013 | 08:28 AM
gonzo082's Avatar
red and yellow(+) black and blue(-). good luck
Old Aug 24, 2013 | 09:39 PM
ikt's Avatar
ikt
you sure?
Old Sep 3, 2013 | 10:28 PM
gonzo082's Avatar
you sure?
Yea that sounds correct. i had to wire my sub in series so i could get 2ohms. some people dont like it, but IMO it sounds good enough
rcheung
Sep 7, 2013 10:18 PM
CasperGSR99
Oct 21, 2010 11:00 PM
Illl
May 26, 2009 12:46 PM
bskidmore6698
Jan 20, 2009 12:19 AM
Red Dragon
11
Jun 19, 2008 02:51 AM
