Aftermarket double din with rf
Old Sep 7, 2014, 06:50 PM
EvoX267's Avatar
So I'm planning on getting an aftermarket double din non navi for my 14 gst with rf and I've been reading all the threads and I'm comfused. I plan on taking out the sub Because I don't really need it. What would I need to make it work properly? I also want to retain steering controls also.
Old Sep 8, 2014, 09:53 AM
jakeleclair2000's Avatar
Parts you will need.
1. Dash Kit - SCOSCHE MI3019B
2. Wiring Harness - AXXESS MITO 03
3. SWC Retention - PAC-AUDIO SWI-RC
Thats it!
Old Sep 8, 2014, 01:28 PM
EvoX267's Avatar
Ok.. becuase i read one thread that said the axxess mito 03 was not working correctly and causing issues. And someone else said something about the amp not working properly.
Old Sep 8, 2014, 01:40 PM
ikt
ikt's Avatar
All the MIT-02 and 03 kinda suck.
Old Sep 8, 2014, 02:08 PM
stiggysaurus's Avatar
You'll need a tech from axxess to come out and reprogram the MITO-03 on the spot for you, that's what I had done on my 2014 w/ RF
Old Sep 8, 2014, 04:04 PM
EvoX267's Avatar
Thats pretty lame that i cant even switch out the lame stock head unit without issues. I should have just got a base model and not soght and sound
Old Sep 10, 2014, 03:48 PM
EvoX267's Avatar
Hopefully axxess fixes the issue. How hard would it be to take the amp out all together and just run the radio without it?
Old Sep 10, 2014, 08:35 PM
i mean, technically it's fixable, it's just not convenient. The audio with my RF system and RF sub works fine after the guy came out to update the MITO - i have a pioneer AVIC-NEX6000
Old Sep 11, 2014, 08:18 AM
@Evox267 - Pulling the amp means that you would have to replace the radio, connect the harnesses that went to the amp, or run new speaker wire, and replace all speakers. you would then have to install an aftermarket amp to power the sub. a lot more work that just using an adapter harness
Old Sep 11, 2014, 11:35 AM
EvoX267's Avatar
I keep reading everywhere that the adaptors are working real crappy with the 2014 rf system. I read somewhere mitsubishi used different wiring because they put in the touch screen which is causing problems.
Old Sep 11, 2014, 12:17 PM
I dont know about changed wiring, but all the MITO harnesses suck. Well, suck in comparison to other factory adaptor harness, like the ones for GM for example.
I have been through 4 MITO 02 harnesses in the wifes 07 Eclipse GT with rockford.
Harnesses 1 & 2 just stopped working one day, the third one wouldn't communicate with the CAN bus, and the 4th one worked great the first week, but now also wont communicate with the can bus.
At this point im done changing harnesses, just saving $$ for a full system replacement.
I have heard some success stories with the MITO pieces, and this is just MY experience with them.
Old Sep 11, 2014, 05:58 PM
EvoX267's Avatar
Not looking good because im hearing more bad experiences than good.
Old Sep 11, 2014, 05:59 PM
EvoX267's Avatar
No one else makes harneses for our car?
Old Sep 11, 2014, 07:13 PM
nope
Old Sep 12, 2014, 02:42 AM
EvoX267's Avatar
Ugh...thats soo lame
Quick Reply: Aftermarket double din with rf
