Heated seats
Old Aug 6, 2017 | 09:25 AM
Evolution_(IX)'s Avatar
Heated seats
Hey I wanna do a heated seat swap just for s**ts in my 08 evo......is is just a straight forward swap ? where do I connect it to ?
Thanks !
Old Aug 10, 2017 | 12:39 PM
Veronica's Avatar
Not straight forward, but can be done.
Some of the wiring harness is there, but you need to run a 12VDC wire from the fuse box.
Buy the switches *with harness*
The wiring is there from the switch to the seats. You will see extra connectors when you remove the old seats.
I used the power outlet in the console (it was close-by) as the switched 12VDC for the relays. BUT! you can forget and leave the seats "on" with key off and drain the battery.
It would be best to run another wire from the fuse box.
Over-all it took maybe 4 hours start to finish.
Old Aug 18, 2017 | 12:28 PM
thanman99's Avatar
sounds like lots of work for little reward
iJHolmes
Jan 14, 2013 07:45 PM
Dr. Fob
Nov 11, 2004 09:21 PM
airlinevomitbag
Mar 11, 2003 09:12 AM
