Excellent gains from the "Buschur Flash", dyno charts attached.
Is the launch control on a clutch position switch? Or is it vehicle speed regulated? If it is a clutch switch, a rocker switch to intercept the switch will probably get around it. And it would still allow you to crank the car over to start when you flip it back. I know it's ghetto but if you're impatient.....
I appreciate the offer, let it all for now. No argueing going on.
Also, update.
We took the car to the track again tonight. Not much better.
The stock clutch, stock RPM launch limit are killing the car's times.
12.66 at 110.XX, don't remember exactly, it was the very first pass of the night. A couple more 12.7's. Overall I am disapointed to be honest. The car is SO much smoother. Seems to be driving right through the clutch. Couldn't get the car out of the 1.80 sixty foot times tonight. Trent was driving again and did his best.
We need a good clutch and a higher launch control, then it's on.
Also, update.
https://www.evolutionm.net/forums/sh...d.php?t=329793
It will also disable the Cruise Control disengagement with the clutch but may be an option for the track.
Also, update.
Also, update.
The "clutch restrictor" in the clutch line is different then the 2 step.
I haven't tried to disable the rev limiter yet, we were going to try it the other night and didn't.
The restrictor will come out when we get enough time to bleed it and mess with it.
So busy................
This is great info. Short, concise and to the point. To me these seem like a safe reliable gains except for killing the clutch, which sounds like will be replaced in even stock evos before to long. I just would like to ride in one of these tuned cars just feel how much smoother they are!!!! Hopefully mine will be one of these tuned cars before 2 long
David Buschur
109
Mar 2, 2011 04:00 PM
Jrod@Buschur
394
Jan 3, 2009 04:53 PM
David Buschur
117
Jul 27, 2008 05:52 AM
David Buschur
35
Jul 23, 2008 10:01 PM
Jrod@Buschur
121
Jun 26, 2008 07:28 AM
