Dyno4mance EcuTeK tuning on Noize's car. Results inside
Wow, and some people have said that the DP did not really do much on the X. Then again who knows how much of that # was due to the test pipe as well....
Would be kind of interesting to so what happened without the DP, but I would imagine that you are in no hurry to pull it back off after what you went through to get it on.
So whats next? The numbers are actually pretty impressive as is, but from what I understand you are only running a TB exhaust, drop in filter and a tune? Are you going to add anything else such as IC piping oa new IC? Just curious as to how far you are going to take this one.
Man, I typed out a nice reply, but am on my wife's laptop, and the frakking browser ate it because I didn't have the "remember me" box ticked.
Anyway, a few things to share:
1) Power is up globally from 3500rpm to the 7500rpm rev limiter.
2) Peak power is from 6000rpm to the rev limiter.
3) With the addition of the test pipe and downpipe, the car spools noticeably quicker.
4) Bruce has a ton of time mapping this car; He and Andrew have been working pretty hard on it. It has 64 pulls on it so far.
5) Boost still tapers to 16psi by redline. I have been reluctant to let Andrew replace the boost pill in the line with a smaller internal diameter one, but I am ready to let them try it next time.
6) This engine allows leaner AFRs on pump gas (while continuing to make power)than the 4G63 does.
7) Injector duty cycles are in the 90% range. With a little more power, there could be fueling issues.
8) The rev limiter needs to go up. I think an extra 300-400rpm would really help this car a ton, as it still peaks on the current limiter.
As far as extra mods are concerned, I'm going to roll like this for awhile. I think Bruce has a little magic left with Mivec and boost taper management with a different pill.
Good deal. I was kind of wondering what your duty cycles were given what some others have found. Has anyone come up with a drop in pump yet? I think that I have read where the good ol' walbro 255 does not just drop right on it as it did on the VIII and IX. The injectors are pretty good size so I would hazzard to guess that the stock pump is not keeping up....
Bruce has been tuning it. He has adjusted Mivec since the start, but would like to work with that more. No pill yet.
I really like Buschur stuff and the staff there is awesome, but I am not looking to cut or remove my undertray at this point. I also am out of mod money at this point.
Its been ECU boost control since last time. They disconnected the MBC. Filter is still in, but post tune, there is not a lot of reason to, other than its washable and sounds kind of cool.
I have the same modifications and was planning on getting my car tuned shortly but wanted to retain the factor boost solenoid's functionality.
I love it. I wouldn't go back to MBC unless I had to.
