10% Ethanol
Old May 8, 2008 | 01:35 PM
Noize's Avatar
EvoM Administrator
10% Ethanol
OK, as of last month, all our local Shell stations use 10% ethanol in their fuel now. I have heard that the entire state is using 10% ethanol, but I have yet to see that verifcation in the form of a sticker on the pumps at other stations.
This becomes more interesting when we think about tuning. You have to assume to keep the (R+M)/2 to be 93 octane, that they are probably using lower octane "gasoline" fuel at the pre-ethanol mix. Ethanol is somewhere near 110 octane.
E85 (85% ethanol) at stoich is around 9.7:1. Gasoline at stoich is 14.7:1. Now it doesn't take rocket science to know that if you have nine parts 14.7:1 and one part 9.7:1, you would have a lower stoich AFR at around 14.2:1. Here come my questions: Would you map everything a tiny bit richer than you used to? Are there any concerns for closed loop fueling, or since the sensors read in lambda, will they automatically adjust to the correct new fueling level?
Thanks,
Seth
Old May 8, 2008 | 01:44 PM
Robevo RS's Avatar
Thanks,
Seth
here in Jersey a long time ago they using 10-15% ethanol.
But i would like to use a 100% even if its cost $2 more, and have a less gas milage.
Old May 8, 2008 | 02:26 PM
Mountainbiker54's Avatar
On that note I just saw this. A possible alternative to us high octane gas guzzlers.
http://gizmodo.com/388542/microfuele...for-pre+orders
Old May 8, 2008 | 02:36 PM
Sky Evo X's Avatar
Great find. Does anyone know the true price per a gallon while making ethanol?
Someone said this on that link
"It will take between 10lbs to 14lbs of sugar to produce 1 gallon of ethanol."
Seems impractical if its true. You would have to store 140 pounds of sugar for just 10 gallons, which does not include the yeast.
Old May 8, 2008 | 02:41 PM
mitsuboost30's Avatar
Just to let u guys know... my friend works at a Gas distrobution center... and EVERY SINGLE GASS STATION ADDS at least 10% if not more Ethanol to there gas!!.
its called an additive.. whether they notify u at the pumps or NOT ITS IN THERE!!!!
IM searious and 10000% positive and correct!
synocois the only gas station that has there own distobution center every other station goes to a universal distributer!!
Old May 8, 2008 | 04:44 PM
CC16's Avatar
He speaks the truth. All the pumps aruond here say "10% Ethanol may be in each gallon" or something similiar to that.
Old May 8, 2008 | 06:09 PM
Noize's Avatar
EvoM Administrator
He might speak the truth for his state, not the entire country. We haven't had nearly as high ethanol content in my state until early April of this year.
Old May 8, 2008 | 08:55 PM
Mightygnu's Avatar
Very interesting thread! Watching this one!
Old May 9, 2008 | 04:34 AM
Talon_66's Avatar
I use 94 octane, w/ Ethanol (ethanol is added after)
Old May 9, 2008 | 05:42 AM
xPRimNT's Avatar
Out of curiosity, how many K's do you get for a tank of the good stuff?
Still trying to gauge whether I should force myself to go 94 for a tune or stick with the easier-to-find 91.
monsta
Jun 23, 2016 01:11 PM
David Buschur
56
Jul 1, 2014 09:57 AM
iTune
E85 / Ethanol
58
Nov 16, 2013 05:58 AM
TTP Engineering
Jul 30, 2009 08:53 PM
Jim in Tucson
E85 / Ethanol
12
Jul 2, 2008 09:50 AM
