Greddy Profec B 2 EBC HELP!
So the install didn't take too long.
at first i plugged everything up and i took it for a test drive.... i was over boosting hitting around 27 psi, then getting thrown into limp mode.
so i checked out the problem, and i was so stupid. I had put the hose that was suppose to come out of the turbo, instead i put it in the intake.
now i test drive it again, all i get is 10 psi... i checked everywhere for boost leak, i didn't find any.
I think the Wastegate is opening before i can build enough boost, but i have never tighten the nut for the wastegate.
today i tried playing with the settings, making gain about 35% and set gain 35 psi.
i could only hit up to 15psi, then i would hear the wastegate open, i would then go back to 10psi.
anyone know what in the world is going on?!
Still having trouble? No wonder you haven't been out. lol
Manual boost control is better than electronic one unless you know what you are doing. My friend once have the Profec B on his 240sx. Got complicated and ditch it for a manual instead. I wish I know to help you out..
Ichigo0Soul
Mar 7, 2016 07:16 PM
05blue8
Aug 17, 2009 03:02 PM
wheredafucrwe
Oct 26, 2004 12:10 AM
