Can the Cobb AP?
Old Dec 23, 2008 | 11:04 AM
tsitalon1's Avatar
Can the Cobb AP?
For Rob@Cobb or anyone who actually OWNS an AP for the X please tell me if I (MYSELF) can use the Access Port to:
1. Adjust open loop Fuel tables
2. Adjust timing tables?
3. Adjust tip-in enrichment?
4. Adjust global injector scaling?
5. Adjust injector dead time?
6. Adjust BCS duty cycles (to change boost levels)?
7. Adjust idle rpm?
8. Adjust rev limit?
9. Adjust launch limit?
10. Log knock?
11. Clear DTC's?
12. Export logged parameters to excel or external format?
13. Log my Wb02 through the AP as well?
14. Surf the web kidding
I am trying to decide between the AP and EcuFlash and this info would be really helpful.
Old Dec 23, 2008 | 12:57 PM
STi2EvoX's Avatar
AP can do everything that ecutek can do, plus has a lot of cool features like data logging and performance monitors (0-60, 1/4, etc.).
Old Dec 23, 2008 | 01:01 PM
Rguy's Avatar
He didnt say anything about ecutek.
Old Dec 23, 2008 | 01:25 PM
dosperado's Avatar
sort of did
Doesn't the AP TunerRace software allow all the custom tweaks?
Old Dec 23, 2008 | 02:51 PM
PR_Mivec's Avatar
i have asked those questions before too and no clear answer yet.. i need to know if you can make those changes WITH the handheld.. i know that w/ the pc you will but i want to know if you can do it on the spot
Old Dec 23, 2008 | 03:10 PM
Papi4baby's Avatar
1. Adjust open loop Fuel tablesDon't know
2. Adjust timing tables?Don't know, suppose to be able to
3. Adjust tip-in enrichment?Don't know
4. Adjust global injector scaling?Don't know
5. Adjust injector dead time?Don't know
6. Adjust BCS duty cycles (to change boost levels)?Suppose to be able to
7. Adjust idle rpm?I was told by Cobb yes
8. Adjust rev limit?Told by Cobb yes
9. Adjust launch limit? Don't know have not ask.
10. Log knock?Yes
11. Clear DTC's?If this is codes, then yes
12. Export logged parameters to excel or external format?I think is also yes
13. Log my Wb02 through the AP as well?I dont think so.
14. Surf the web kiddingYesssss, lol
Most of what you want has to be done with the tunning software. The logging is done with the AP itself, and you get it in a number and tables format from what i have read and you can export it to excel and even make charts i hear(from another member).
Hofully Rob will chime in.
Old Dec 23, 2008 | 03:54 PM
ADVANT123's Avatar
7. Adjust idle rpm?
10. Log knock?
11. Clear DTC's?
I believe at the moment the only software available to tune the AccessPort is the pro-software, not the free program that Cobb plans on releasing. So the answer would be "No".
Old Dec 23, 2008 | 08:00 PM
RazorLab's Avatar
7. Adjust idle rpm?
10. Log knock?
11. Clear DTC's?
1 through 9 you will be able to do once Race Tuner is out
10,11,12 you can currently do with the AP unit.
Old Dec 24, 2008 | 06:15 PM
dcasandman's Avatar
I think one of the Pro tuners has to chime in here. You can not self tune with it at this time, so just AP owners probably would not the extent of its capabilities. It is suppose to be as comprehensive as Eccutek. I know for sure it does many in the list, but not sure about all.
Old Dec 25, 2008 | 03:11 AM
nhoj's Avatar
Currently..
1. Adjust open loop Fuel tables No.
2. Adjust timing tables? No.
3. Adjust tip-in enrichment? No.
4. Adjust global injector scaling? No.
5. Adjust injector dead time? No.
6. Adjust BCS duty cycles (to change boost levels)? No.
7. Adjust idle rpm? No.
8. Adjust rev limit? No.
9. Adjust launch limit?No.
10. Log knock? YES
11. Clear DTC's? YES
12. Export logged parameters to excel or external format? YES, excel.
13. Log my Wb02 through the AP as well? I don't think they released support yet
14. Surf the web kiddingNo.
However, like Razorlab said, the "No's" should be enabled once the new Racer Tuner is released.. (minus #14)
Old Jan 6, 2009 | 07:03 PM
Black-X's Avatar
So can we adjust the idle rpm slightly to stop the weird up and down thing?
-X
boyvang
Jun 3, 2015 01:09 PM
Kaizen Tuning
Kaizen Tuning
15
Nov 6, 2014 04:38 PM
Boba
23
Sep 16, 2009 11:29 AM
pltek
Mar 17, 2009 07:33 AM
