ECUFLASH for X: Glossary for Dummies !
RED ITEMS NEED COLLABORATION, PLEASE FEEL FREE TO PM ME OR POST AND I WILL UPDATE
hello i wanted to start this thread so that all people could contribute and define all the maps for those of us who like to learn how to " tweek" things. some of these things will be taken from other threads on this forum, some from posts, some from PMs to me,
this is a work in progress and will be updated from either people posting or PM-ing me, at least thats the idea,
lets see how far we can get.
Second post will be reserved for helpful hints in tuning such as boost pills, calibrating intakes, scaling injectors, Tephra mods, etc
Sso if you want to contribute here we go:
TIMING:
-High Octane Timing Map: This is the main Ignition timing map that the ECU uses at all times if there is no substantial knock or other problems. This is based off RPM and Load.)
-Low Octane Timing Map: secondary Ignition timing map, milder timing in case of knock detection
-MIVEC Intake#1: camshaft timing/lift adjustment, ECT<77decC
-MIVEC Intake#2: camshaft timing/lift adjustment, ECT>77decC
-MIVEC Exhaust#1: camshaft timing/lift adjustment, ECT<77decC
-MIVEC Exhaust#2: camshaft timing/lift adjustment, ECT>77decC
-Ignition WarmUp Retard
-EGR Timing Advance
FUEL:
-High Octane Fuel Map: main fueling map ECU uses in Open Loop mode
-Low Octane Fuel Map: secondary fueling map, milder AFR in case of knock detection
-Max Rich AFR Clip vs Coolant Temp
-Fuel Injector Scaling: reflects injector size, changed when upgrading injectors
-Injector Battery Voltage Latency Compensation: used to change injector latency v. battery voltage.
-Injector Base Latency
-Evap Map #1
-Evap Map #2
-Open Loop Load Low Octane #1: point at which ecu swithes from closed loop (02 sensor 14.7:1AFR) to open loop fueling(looking at fuel maps)
-Open Loop Load Low Octane #2
-Open Loop Load Low Octane #3
-Open Loop Load Low Octane #4
-Cylinder Fuel Trim #1
-Cylinder Fuel Trim #2
-Cylinder Fuel Trim #3
-Cylinder Fuel Trim #4
TURBO:
-Boost Control Load Offset: This number + Boost Target Engine Load number = Target Load
-Boost Target Engine Load #1A (High Gear Range)
-Boost Target Engine Load #1B (High Gear Range)
-Boost Target Engine Load #2 (Low Gear Range)
-Reactive Solenoid Base WGDC Map #1A (High Gear Range): used to set boost level using primary selonoid WGDC plotted against Throttle Position and RPM
-Reactive Solenoid Base WGDC Map #1B (High Gear Range): same as above
-Reactive Solenoid Base WGDC Map #2 (Low Gear Range): same as above
-Reactive Solenoid WGDC Correction Interval (High Gear Range)
-Reactive Solenoid Turbo Boost Error Correction: If the engine load is above or below the "Target Load" (see Boost Control Load Offset + Boost Target Engine Load tables) by a certain percentage, then actual wastegate duty cycle is added or subtracted depending on this table.
-Reactive Solenoid Max Total Upward WGDC Correction vs TPS
-Reactive Solenoid Max Total Downward WGDC Correction
-Passive Solenoid Base WGDC Map #1A (High Gear Range)
-Passive Solenoid Base WGDC Map #1B (High Gear Range)
-Passive Solenoid Base WGDC Map #2 (Low Gear Range)
-Boost Control RPM Per MPH Xover (Gear Based)
-Boost Limit: Allowable load at given RPM, if exceeded fuel cut will take place
-Boost Cut Delay Timer: The number in this map (miliseconds) is the amount of time it takes before your boost cut (more accurately fuel cut) kicks in.
INTAKE:
-Throttle Map#1
-Throttle Map#2
-Throttle Map#3
-Throttle Map#4
-Throttle Map#5
-Throttle Conditional Switch
LIMITS:
-Rev Limiter
-Stationary Rev Limiter
-Speed Limiter
-Airflow Check#1
-Airflow Check#2
-Airflow Check#3
-Airflow Check#4
-Torque Limiter#1
-Torque Limiter#2
-Torque Limiter#3
-Torque Limiter#4
-Flow Check Table
TIMING:
-EGR Timing Advance
FUEL:
-Evap Map #1
-Evap Map #2
TURBO:
INTAKE:
-Throttle Map#1
-Throttle Map#2
-Throttle Map#3
-Throttle Map#4
-Throttle Map#5
LIMITS:
-Rev Limiter
-Speed Limiter
-Airflow Check#1
-Airflow Check#2
-Airflow Check#3
-Airflow Check#4
-Torque Limiter#1
-Torque Limiter#2
-Torque Limiter#3
-Torque Limiter#4
-Flow Check Table
1. How to get more boost with OEM boost selonoid maps (pill)
-gst explaining upgraded pill at the turbo pressure side, #65 (click here)
2. Scaling Injectors
3. Calibrating Intake
4. Tephra Mods
5. Basics on how to tune an Evo (click here)
6. how to tune the X on E85
7. how to get rid of throttle hang
4. Tephra Mods
It would be nice if someone would be kind enough to create a sticky similar to the one in the Evolution 1-9 forum.
https://www.evolutionm.net/forums/ec...-tune-evo.html
COBB Tuning
Cobb AccessPORT
26
Jan 4, 2013 01:17 AM
Clipse3GT
18
Dec 22, 2010 05:42 AM
crimson red
Sep 8, 2010 06:14 AM
