Optimal and maximum EGT levels for Evo X?
Old Dec 24, 2008 | 12:45 PM
Mojito's Avatar
What is the maximum level of EGT for Evo X when it becomes dangerous for the motor? If you drive at max speed at WOT (I guess that's as hot as it can get) what shout the EGT be then?
Old Dec 25, 2008 | 10:17 PM
STi2EvoX's Avatar
Perrin did a test a while back and they said that the EGTs in the X get pretty hot, as high as like 1650 I think. Look back in the turbo/drivetrain section for the ic temp test thread by perrin and the info is in there.
Old Dec 26, 2008 | 06:34 AM
Noize's Avatar
EvoM Administrator
1550 is the most you'd like to see safely for a piston engine. 1650 for a rotary. They can go higher, of course, but you need to be careful above that.
moey124
Apr 14, 2008 10:40 AM
wrcwannabe
10
Apr 25, 2007 03:56 PM
Anarchy99
10
Mar 8, 2006 08:28 AM
Tek3Evo
16
Jul 6, 2005 10:59 PM
evo8dad
33
Jun 5, 2005 05:01 PM
