What EGT are people seeing
Old Apr 22, 2007 | 07:39 PM
wrcwannabe's Avatar
I just installed an Autometer EGT Sport Comp II on my 05 MR tonite . Currently the car is stock with the exception of Forge EVO15 DV and Forge WGA plus my own custom flash . Car runs 22-23 max with taper to 19 at 7K . On 93 octane, I consistently log very few knocksums 1-2 cells of 2-3 ks 2500- 3500 thats it. 230-240 load region
what EGT should i be seeing at this level of tune ? I havent even started the car yet..too tired after work, cutting the yard and then doing the install LOL
Jack Ted ? any experts ?
Thanks
Old Apr 25, 2007 | 06:07 AM
wrcwannabe's Avatar
Wow 37 views and no responses ... OK i get 900 F at idle and 1100-1200 F driving around no boost. WOT for short bursts like 1-2-3 I get 1500-1600 F
I will coorelate this to my wideband soon ...cruise and WOT pulls
Milburn
Old Apr 25, 2007 | 06:09 AM
Slick-IX's Avatar
im a noob, i dunno
Old Apr 25, 2007 | 06:15 AM
Ph3n1x's Avatar
1350-1400F Cruise at 85mph IIRC
950F Idle
1150-1250 Light Cruisde
1402-1725F at WOT (Beginning 3.5k - 7k- highest temps are for a slight moment after 6k)
Of course in a perfect world 1650f is the max you would want.
Old Apr 25, 2007 | 06:24 AM
BoostEEd's Avatar
Milburn
Sounds about right, but depends on your mods.
Old Apr 25, 2007 | 07:14 AM
Gsr Mann's Avatar
Are those readings pre or post turbo ?
I installed my EGT probe after the turbo, I am wondering what my max reading should be since the probe is not at the hottest point of the engine.
Old Apr 25, 2007 | 07:50 AM
BoostEEd's Avatar
Those are pre turbo. Its hard to get an accurate reading post turbo.
Old Apr 25, 2007 | 11:50 AM
Gsr Mann's Avatar
BoostEEd,
Is there a conversion factor or add on guestimate that can be used to determine the
safeness of my EGT reading.
Mine is in the downpipe, I go as high as 1325f I do not sustain that temp for a long time as I am not sure how safe it is to do so.
Old Apr 25, 2007 | 12:06 PM
BoostEEd's Avatar
BoostEEd,
Yes and no.
Mine was there when I bought it. I think I considered 1400 or so my redline. Not sure really. Its hard to say how much heat is dissipated in the turbo. I actually had two senders hooked up at the same time and meant to compare them but I have switched downpipes now. There is talk around here cause I know I asked that same thing when I first got my evo just trying to figure what the safe limit is....
I'll see if I can find it.
Old Apr 25, 2007 | 12:09 PM
BoostEEd's Avatar
here it is:
https://www.evolutionm.net/forums/sh...d.php?t=247915
Old Apr 25, 2007 | 03:56 PM
Gsr Mann's Avatar
BoostEEd
Thanks for the info & the prompt response.
Chabada15
31
Jun 12, 2008 07:01 PM
EVO8HKS
15
Jul 15, 2007 04:57 AM
Danny23
Dec 21, 2006 06:41 PM
racerferrari
Jan 8, 2005 11:17 AM
silverEVO8
31
Jun 14, 2003 07:42 PM
