Evo X ROM disassembly/interpretation discussion
Old Feb 3, 2009 | 06:33 PM
  #76
madcows's Avatar
Any idea if those figures are measured in metric/standard units? Also, if this table is used in open loop operation is it likely that it doesn't correct these figures based on air temp? Lastly, when does the ECU run open loop vs closed?
Old Feb 3, 2009 | 06:42 PM
  #77
gunzo's Avatar
These are numbers only .. MrFred sees them as absolute where I see them as Gauge ..
whatever he defines and I define is OUR definition .. as in we try to explain to people what they mean in our own way ..
so saying .. the original programmer of the ROM may have different numbers
As for open/close loop .. there's another table that does this ..
Old Feb 3, 2009 | 06:54 PM
  #78
madcows's Avatar
Gotcha
It would be safe to say whatever make believe units mitsu uses would also match that of the figures generated by the MAS computations, right?
Old Feb 5, 2009 | 04:02 AM
  #79
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
EVO X OBD Table
I have started disassembling EVOX , here comes first fruit of it:
52680018 handles it in sub_955AC
OBD Table = 00094B08
mrfred can you PM me Colby's script for those indirect RAM adresses?
Old Feb 5, 2009 | 08:10 PM
  #80
mrfred's Avatar
I put fixfp on my ftp site. If you plan to use it on a non-Evo 10 ROM, it might be necessary to modify the script to point to the correct FP reference address.
What is the sub at 955AC? I don't see any refs to any subs that I've examined.
Old Feb 5, 2009 | 09:42 PM
  #81
acamus's Avatar
One could call it OBD_CODE_LOOKUP it does the same as 0003A05C in 88590015.
I know i have to find the base address, nevertheless I believe it is the same,
I haven't read the m32r manual completely yet, maybe I will figure out Colby's path.
Old Feb 5, 2009 | 09:47 PM
  #82
mrfred's Avatar
Its pretty easy to find the FP ref. Just look at its location in the Evo 10 ROM, and you'll understand how to find it in other M32R ROMs.
Old Jan 3, 2020 | 04:18 PM
  #83
ROB-80E's Avatar
Thread from the dead.
Did anyone figure out if the the sp reference (stack pointer) has any relevance in finding addresses and lookups?
Eg,
st R2, @(0xC, sp)
I can't find a specific base like the 80C000 for the frame pointer. Only commands that add, load or store to an immediate value.
I'm just finding code that loads from the stack pointer offset and then saves to the frame pointer offset.
ld R0, @(0x24, sp)
st R0, @(0x6524, fp)
hackish
Oct 7, 2009 10:31 AM
jcsbanks
Apr 18, 2009 03:10 PM
EvilEVO800hp
17
Jan 22, 2007 10:35 PM
Zam
Aug 8, 2006 03:47 PM
