Z chip or Cobb Accessport for the X
Old Jan 8, 2009 | 09:39 PM
  #31
aiden1983's Avatar
Originally Posted by GST Motorsports
Does your evo drive itself? Weight inputted is plus the driver.
Even if the weight being used is blotted or reduced much it will not really affect the power output much on the mustang dyno, TTP explained the reason above so I won't retype it.
Ya but isnt that a gsr so that means you have +400lbs of driver and gear? If they do it just to make more realistic ET like they said thats fine, I just thought the weight was a little high. I didn't think it would give you "generous numbers" or anything like that.
Old Jan 9, 2009 | 05:28 AM
  #32
Robevo RS's Avatar
I'm kinda confused. The Z-chip can manipulate the Rev limit also?
Because in this drag video prep you put it out you say, you run
11.83 sec @ 116.3 on drag dyno. As a prearation for a drag strip.
But clearly you never shifted the 5th gear. So how that is possible with the factory rev limit?
Can you comment on that?
Thanks Rob
http://www.youtube.com/watch?v=37qNQcwSmI4
Old Jan 9, 2009 | 05:56 AM
  #33
TTP Engineering's Avatar
The information has already been provided. Read the thread.
Originally Posted by TTP Engineering
The ZChip for Evo X, MR and Ralliart 2009 modifies the following functions of the ECU without writing on the ECU.
MIVEC intake and exhaust
All ignition timing maps
All fuel maps
DBW maps
TPS maps
Airflow maps
Boost limits
MAP scaling
And it does is all for $399, is plug and play and does not require custom tuning at an hourly charge. It is able to be installed by the end user in 10 minutes, removed in 5 minutes, leaves no trace of changes on the ECU, does not require the removing and mailing of the ECU anywhere.
It is the only USER tunable solution in the market today for these three models.
It seems to mimic the success rate of the ZChip's over 100 units sold worldwide in a number of countries. Heck the only Evo X in Kuwait has a ZChip
Old Jan 9, 2009 | 06:55 PM
  #34
GST Motorsports's Avatar
The X weighs around 35XX and the 8/9 weigh around 33XX
Add approx 170-200 for driver (tuner) on the dyno and that is the weight you get.
Obviously nobody really weighs every single evo before it gets on the dyno so approx weights are used for every evo unless it is a significantly lightened Evo. At least this is what I do on our dyno.
Old Jan 9, 2009 | 06:58 PM
  #35
aiden1983's Avatar
thanks for the clarification
Old Jan 10, 2009 | 05:20 PM
  #36
dcasandman's Avatar
Thanks Rob
Good question.
Old Jan 19, 2009 | 06:07 PM
  #37
GoKimiGO's Avatar
Originally Posted by GsrEviluTionX
Sorry guys first let me welcome myself, 1st post purchased my silver evo x about 2 days ago with 2 miles on it, now has 200 miles!
Well anyway been searching and reading up on tuning, i wiould like to keep it lightly modifed. Now i have already done the drop in intake, now for tuning on your opinion which should i get and which would lead me to btter results.
Z chip or Cobb accessport?
I read up on both, and search past threads but before i buy figure i would ask to see if anyone has tried both or know anything else?
Go with the COBB AccessPort.
No splicing, no signs of ever being modified if you should ever choose to revert back to your stock configuration. It has the best functionality of anything else I have seen, including recovery tools should anything wacky happen during the install that is over in about 5 minutes
You can store up to 20 different maps! Including these that are pre-installed with the unit: economy mode for better gas mileage, valet mode to protect your car from being abused by someone other than you , anti-theft mode which won't let your car be started until you unlock it again using the AP, performance minded pre-programmed maps for 91 & 93 octane. New maps will be released by no only COBB but also other tuners and end user in the coming months. There is also the best part of all, the ability to go to tons of custom tuners around the country and get customized maps for your specific mods. You can flash all these maps yourself once stored on the AP at your convenience in under 30 seconds. The possibilities are endless
COBB has also released Access Tuner where you can create your own maps if you are savvy with tuning (even connect your laptop to your OBD2 port and do live tuning!).
Plus flashing the ECU is the only way to alter parameters such as the rev limit.
You also get live data from your car including voltage, MAF, TPS, RPM and many many more.
Also live data logging built in!
It also has a performance meter that will spit out 1/4 mile times and MPH if you are into that sort of thing
Another great thing is that down the line if you should choose to part with it you can sell the unit and recoup some of your cash to not only other Evo X owners but any other car that is compatible with the AP, including the STi, GTR, Mazda 3s, WRX and lots more that can be seen on their website.
It is really a great, easy to use and full featured unit. I just installed mine tonight and could not be happier. I'm not telling you to get one just because I got one. I think I would have gone with ECUtek had the AP not been around, but this gives you everything the ECUtek does plus so much more.
It is a bit pricier but very much worth it in my eyes.
Good luck with your decision and do lots of research before purchasing, that is what I did
Last edited by GoKimiGO; Jan 21, 2009 at 06:27 PM. Reason: COBB updated features and performance!
Old Jan 20, 2009 | 05:34 AM
  #38
EvoG8r's Avatar
Cobb AP is a little more proven, but the z-chip has made power for other people.
Old Jan 20, 2009 | 07:58 AM
  #39
Rob@cobbtuning's Avatar
Keep in mind it's all about the tuning. The motor is only able to produce XXX power in a particular state. It does not matter what tuning solution puts it to those peak power levels as long as it's a capable solution. From there it's about flexibility and how smooth you can get the part/full throttle transitions between open and closed loop. Being able to modify any of the ECU's internal parameters to achieve a more rounded tune is a huge benefit. Anyone can make WOT power. Where the expertise comes in is the part throttle tuning.
Using a device to manipulate an already rough tune to do it's bidding is not the best idea for smooth daily operation. Or trying to dance around the max airflow or torque limits when you could simply modify them in the ECU to add power instead of limit in those areas.
A piggie back is simply a no where near as comprehensive and extensible of a solution as a well setup ECU flashing solution. The ECU flashing solution will be able to make the most of the power the engine has to offer everywhere on the curve.
Thanks,
Old Jan 20, 2009 | 10:35 AM
  #40
The ZChip is an excellent choice for many reasons not limited to its pricing point at $399.
Its ability to meet and exceed the power output of any other tuning method.
The part throttle response in our opinion is much better with the ZChip in our experience thus far
The ZChip has no need to "dance around" any limits in the ECU. It merely optimizes the state of tune, improves the efficiency of the engine while creating power and torque with no side affects and no WRITING over the FACTORY ECU mapping.
Old Jan 20, 2009 | 11:19 AM
  #41
Kurt's Avatar
Cross posting is not allowed. Any future attempts will lead to points and/or a ban.
Thread cleaned.
Old Jan 20, 2009 | 11:58 AM
  #42
A piggie back is tricking the ECU into using it's stock (rough) tune how the piggie back wants. It's still subject to the limits and stock values of the ECU and there for must <insert your favorite verb here> around those limits and stock values.
"WRITING over the FACTORY ECU mapping" would be an incorrect use of terminology. The AP users stock tune is safely kept until the user would like to uninstall at which time the 100% original map is flashed back into the ECU with no ill effect or permanent installation damage.
Thanks,
Old Jan 20, 2009 | 12:48 PM
  #43
GoKimiGO's Avatar
What side effects does flashing ECU have? Please explain.
You are making is sound as if flashing the ECU is a bad thing.
Old Jan 20, 2009 | 03:47 PM
  #44
wwevox4me's Avatar
I love my cobb ap.
Old Jan 20, 2009 | 05:51 PM
  #45
mrfred's Avatar
If you're limiting yourself to either the Z-chip or the AccessPort, hands down the AP the better choice. Zeitronix is a great company, and the Z-chip is a very nifty "first to market" solution to tune the Evo 10, but it provides only indirect means to tune the car. The Z-chip alters the MAP signal to make the ECU think the load is higher or lower than what it really is. (BTW, the use of the MAP sensor to alter load is fascinating because it suggests that the Evo 10 is speed-density based for open loop driving.) By remapping the load response, the car is essentially tricked into running different timing, AFR, MIVEC, etc. Careful manipulation of the remapped load leads to improved performance by running more timing, running a leaner AFR, etc. It apparently works quite well in the correct hands, but its still an indirect tuning tool, and a direct tuning tool like the AP can always do better (again, if in the correct hands).
