Mivec advantage?
Old Nov 4, 2009 | 09:04 AM
  #121
crcain's Avatar
From what I think was originally a Hi-Boost cut and paste:
Since the intake valve closes after the bottom of the intake stroke, closing the intake valve earlier gives you a longer compression stroke, and higher peak cylinder pressure.
But at higher RPMs the valves are open for a much shorter period - with the later intake opening there is not enough time for the cylinder to fill so the peak pressure actually drops off.
Ok the first part, advancing the intake yields higher peak cylinder pressure makes sense.
But the second part confuses me. I understand as RPM rises the duration in time the valves are open reduces. But how does this effect intake cam timing? With ignition advance it is easy, you start earlier to give the flame front time to build. But with valve timing I don't quite get it.
Old Nov 4, 2009 | 12:31 PM
  #122
H Jensen's Avatar
I could be wrong but this is the way I understand as to how it would work.
If you advance your cam timing your allowing your cylinder to start filling sooner and add the vacuum that's created when the piston is traveling down your filling the cylinder better. In other words (depending on your valve overlap) your at the end of exhaust stroke your intake valve just opens and your exhaust valve is closing causing scavenging/your pushing exhaust out with boost. now before your piston starts the intake stroke your already filling the combustion chamber with air/fuel and creating cylinder pressure, now when that exhaust valve closes and the piston is going down your still adding more air/fuel. Now wherever that intake valve closes either before BDC or at BDC you now have filled your cylinder with the most air/fuel you can. Compared to having your intake at stock timing.
Old Nov 4, 2009 | 01:59 PM
  #123
UT_EvoX's Avatar
Eh, pretty much. But having the exhaust overlap the intake allows the exhaust pulse to actually pull fresh air into the cylinder, reducing pumping losses. This works great under vacuum, but is not beneficial (and actually detrimental) once you hit full boost. At that point, your turbocharger will literally force compressed air straight through the cylinder while the exhaust valves are still open.
Old Nov 4, 2009 | 05:12 PM
  #124
tephra's Avatar
ok another topic.
Compressor Surge.
I retarded the exhaust cam by an additional 2.5 degreees. and all of a sudden my WOT "load" got all jumpy.. also the car felt a bit grumpy.
is this a sign of compressor surge?
Old Nov 5, 2009 | 12:21 AM
  #125
gunzo's Avatar
Originally Posted by tephra
ok another topic.
Compressor Surge.
depends on when it happens .. that is onset of surge ..
another clue to queue you in is the tubo sound changes .. like an approaching helicopter ..
And whatever Bryan says on dynamic boost
CrCain .. fuel is only injected near the end of the intake phase .. not at the beginning ..
Old Nov 5, 2009 | 05:02 AM
  #126
tephra's Avatar
happens after spool, i pulled out 1 degree of ex-retard...so ill do another log tommorow..
Old Nov 5, 2009 | 05:34 AM
  #127
crcain's Avatar
So it's unlikely there is much fuel in the charge during overlap?
Do we know the injection angles for the stock ECU or is that a mystery?
Old Nov 6, 2009 | 06:11 PM
  #128
gunzo's Avatar
Remove the exhaust restriction my friend
Old Nov 6, 2009 | 06:12 PM
  #129
tephra's Avatar
yeah thats what I am thinking as well.
Old Nov 6, 2009 | 11:19 PM
  #130
Hiboost's Avatar
ok another topic.
Compressor Surge.
Only used to happen in 5th for me if i exceeded 20 psi by 3400 in 5th. After I did some light port and polishing to my exhaust side and switched to a shorter runner/higher velocity exhaust manifold I haven't been able to trigger it yet and the car feels more responsive and pulls at 25 psi like it did at 27 psi before. I'll have to do some full logging tomorrow to verify but balancing more velocity and volume through the exahust side definitely can counter compessor surge as can mivec tuning where less intake advance and less exhaust retard will settle down the overactive spoolup.
Old Jun 1, 2010 | 08:49 PM
  #131
criptballer's Avatar
this is a great thread revival! any more theories or proven theories that work with FP Reds? i'm trying one out tomorrow and i'll let you guys know how it went.
Old Jun 2, 2010 | 05:47 AM
  #132
newcomer81's Avatar
prepare for an epic battle between surge and quick spool... i ended up reducing 3rd gear spool to lessen 4th gear surge.
time to go post a suggestion in the tehpra mod thread
Old Jun 2, 2010 | 09:01 AM
  #133
well i have the anti surge Red (not that it helps a ton, but it helps some) Im also having gunzo make my mivec gear dependent so i don't surge while i'm on the freeway at 5th, other than that, i've learned to live with the surge i already have.
Old Jun 2, 2010 | 09:48 AM
  #134
newcomer81's Avatar
i was getting some great spool numbers (20psi 3550rpm, 27psi 3800rpm) but 4th gear surge was too much. I ended up dropping 3rd spool down 200 rpms . I don't have the anti-surge housing so you should be able to get away with more aggressive maps. mivec is pretty damn cool.
Old Jun 3, 2010 | 04:34 AM
  #135
Fourdoor's Avatar
How different are the "warmup" and "normal" stock tune MIVEC maps for the EVO X? A quick look at my stock Ralliart map the #1 and #2 maps are identical! They also appear to be more aggressive in the lower RPM / load areas and less aggressive in the upper load / RPM areas than the stock USDM EVO X MIVEC maps. This is based on GST's post (post #20) comparing stock USDM and stock JDM MIVEC maps... are those the actual stock USDM maps there? I will post up screen shots of my stock MIVEC maps for comparison.
Hey Bryan, if you are still following this thread do your stock Ralliart MIVEC maps 55590007 match mine from 55590006? Are your "warmup" and "aggressive" maps identical in your stock ROM like they are in mine?
Thanks,
Keith
Attached Thumbnails Mivec advantage?-ralliart-mivec-int.jpg   Mivec advantage?-ralliart-mivec-exh.jpg
