Tuning questions
Tuning questions
I've been reading the threads and trying to get a realistic idea of what to expect for HP gains out of these cars. I see a great number of products out there and I guess my question is what products really produce the most HP/bang for the buck. I'm thinking I'd like to hit 350 RWHP but i don't want to break the bank and I want a rock solid dependable car as this is my daily driver. So access port, tune, pill?, exhaust?, cold air intake? what should I be looking at?
AP + pill (or MBC) + drop in filter + exhaust + down pipe + tune will get you very close is my guess... worst case add on a FMIC and IC pipes and should put you north of 350 for sure ... but then again depends on the tuner
Best bang for the buck is a tune without a doubt. You should see 50 - 60 whp gain from custom tuning alone with no after market parts.
3" turbo back will run in the 1,000 to 1,500 and is good for another 10-20 whp peak but lots of area under the curve
Upper IC pipe figure 150 - 350 depending on brand and may bee good for up to 10whp
Drop in filter will run 50 - 100 and depending on brand could net 0 - 10 whp
With all of the above you would be in the 295 - 310 whp range on an uncorrected dynodynamics. Or 343 - 360 whp on a typical dynojet.
At this point you will be out of injector and need to start looking for fuel system upgrades.
Save yourself a little money and get all the hard parts purchased and installed before your tune.
I have just about all the bolt-ons now minus a intake (I do have HKS dropin). My car made 341whp on a mustang dyno with a custom tune with the AP at Cobb Tuning in Plano, Tx. I do have a Pill and my boost peaks at 27 and tapers to 21-22.
I picked up about 10whp between the filter and the hot side Intercooler Pipe.
