ECUFlash 1.41 released
Old Feb 13, 2009 | 12:21 PM
  #136
nj1266's Avatar
Originally Posted by GST Motorsports
Thanks Bryan.
Can the data be posted in a log file that can be read by Excel? Or is this the only way to display data with PCMscan?
The image show 35 psi of boost. I doubt this is on an Evo X. Is it?
Old Feb 13, 2009 | 01:49 PM
  #137
nj1266's Avatar
So I paid to get the license key for PCMscan. When will I get an e-mail notification with the key? I need it this Sunday. Those who bought this please chime in.
thanks
Old Feb 13, 2009 | 02:32 PM
  #138
SiC's Avatar
SiC
Originally Posted by nj1266
I could not open the zip file. I got an error code
Can you please e-mail the log to ndahi@charter.net
Thanks
I don't know what's wrong, the file seems to get screwed up when I upload it. I sent you an email.
Old Feb 13, 2009 | 02:37 PM
  #139
A418t81's Avatar
Thanks Bryan.
More than likely that is absolute MAP in. Probably ~22 psi positive pressure.
Old Feb 13, 2009 | 02:58 PM
  #140
SiC's Avatar
SiC
For those who want to view a PCMScan log, click here.
Old Feb 13, 2009 | 04:04 PM
  #141
nj1266's Avatar
SiC, Thanks.
Bryan, can you please post a stock log in csv format somewhere so we can view it.
Thanks
Old Feb 13, 2009 | 04:33 PM
  #142
stokEd's Avatar
thanks
It may take a few hours for your key to arrive via e-mail.
Old Feb 14, 2009 | 09:24 AM
  #143
xbox4414's Avatar
Is there any other way to read or datalog? Is there an easier way to read PCMScan such as like below:
Old Feb 14, 2009 | 09:53 AM
  #144
flagg77's Avatar
^Yup, you can create tables and then define the X, Y and cell PIDs. Takes a bit to get the formatting and min/max values, but its perfectly doable.
Old Feb 14, 2009 | 10:45 AM
  #145
xbox4414's Avatar
Ya I'm trying to figure those out...anyone have them set up already? I've been playing with the tables but I can't get the scaling and values right, haha.
Old Feb 14, 2009 | 10:46 AM
  #146
stokEd's Avatar
What exactly are you having trouble with?
Old Feb 14, 2009 | 10:54 AM
  #147
xbox4414's Avatar
Just trying to set up the map settings for the tables.... I don't know how to scale them. Like the Label Format String, Cell Value Format String, ect. Anyone have a premade table layout or something?
Old Feb 14, 2009 | 11:13 AM
  #148
flagg77's Avatar
I use:
col pid: sae.load_abs
row pid: sae.rpm
cell value pid: script.boot (english)
Metrics Tab:
min = 0 / median = 15 / max = 40
cell value format string: %1.1f
show value type: last value (theres options here to avg out if you like)
Colums Tab:
Col Count: 22 min = 0
Col Size: 50 max = 335
Label format: %1.f multplier = 1
Rows Tab:
Row Count: 23 min = 0
Row Size: 15 max = 8341
That should give you the table you were asking for initially. You can then modify the pids used to get a similar table for ign. timing.
Old Feb 14, 2009 | 11:20 AM
  #149
xbox4414's Avatar
Okay thanks that helps a lot!!!
What about the scaling for timing. What should the min, med, and max be?
Also what about load? Such as below:
Old Feb 17, 2009 | 07:34 PM
  #150
verkion's Avatar
Sorry if this is a dumb question...but how are you getting the boost to log? I tried using the "script.boost" and it doesn't show anything...
Thanks!
verkion
