ECU Flash on P1245 code
Old Feb 1, 2009 | 12:38 PM
burnings's Avatar
ECU Flash on P1235 code
Hi gurus,
Currenly, I have raised the Boost delay to 1638375. Does that effectively remove the P1235 error? Or do I have to edit the Airflow check and torque limiter as well?
Old Feb 1, 2009 | 01:11 PM
GST Motorsports's Avatar
You need to map the BDEL tables as well.
Old Feb 1, 2009 | 07:12 PM
TTP Engineering's Avatar
It will remove the fuel cut, but not the limp mode.
Old Feb 1, 2009 | 07:13 PM
PR_Mivec's Avatar
boost cut delay timer?
Old Feb 1, 2009 | 08:37 PM
SiC's Avatar
SiC
Boost Cut Delay Timer
The number in this map (miliseconds) is the amount of time it takes before your boost cut kicks in.
Example: Lets say your boost limit (numbers are in load) is set to 250 load at 4000 RPM and you increased the boost on your car so the load jumped to 260. The stock boost cut delay is set to 1 second (1000 ms) so it will allow your car to go beyond it's load limit for 1 second. If your load is beyond it's limit for more than 1 second, the boost cut will kick in. If you change it to 5000ms, it will allow your load to go beyond it's limit for 5 seconds.
But like TTP said, this will only prevent the boost cut and will not prevent the CEL.
Old Feb 1, 2009 | 11:47 PM
burnings's Avatar
What's BDEL???
Old Feb 2, 2009 | 12:41 AM
SiC's Avatar
SiC
Originally Posted by burnings
What's BDEL???
Boost Desired Engine Load
Aka Boost Target Engine Load in ECUFlash
Old Feb 2, 2009 | 12:58 AM
burnings's Avatar
I only have Boost Target Engine Load #1A, #1B and #2... is that the table?
If yes, does that mean that I need to increase the Throttle %?
Old Feb 2, 2009 | 01:18 AM
SiC's Avatar
SiC
Yes those maps are the same as BDEL.
The parameters you see in those maps are load values, the scale is in RPM x Thottle %.
Boost Control Load Offset + BDEL = Target Load (the load you want to hit)
Adjust the Boost Control Load Offset and the BDEL to match the engine load you desire.
Old Feb 2, 2009 | 03:13 AM
burnings's Avatar
So that means that I can safely multiply everything by 20% and hopefully I wun hit a Limp mode on part throttle...
Old Feb 2, 2009 | 03:25 AM
burnings's Avatar
I forgot to mention that I have EBC installed so does that makes things simpler?
Old Feb 2, 2009 | 03:58 AM
SiC's Avatar
SiC
By what percent you increase is up to you hit & miss my friend, this is how we all learn.
I would also recommend adjusting 2 more sets of maps, Airflow Check #1-3 & Torque Limit #1-3. You can increase these maps up to about 30% depending on the throttle voltage & RPM. And again, the amount you increase is up to you
gunzo has released a base map for USDMs on 91 Oct, that map may be a good starting point for your tune.
Old Feb 2, 2009 | 10:48 AM
If you have a EBC installed and are not using the stock ecu to control boost at all, just raise the Boost Offset from 80 (stock) to something large like 300 or so. That way you don't even have to touch target engine load maps.
Old Feb 2, 2009 | 12:42 PM
PR_Mivec's Avatar
this was exactly my concern regarding the EBC
what i did was to raise the "boost limit" to the max, so far no trouble code at part throttle or any code related
Old Feb 2, 2009 | 01:50 PM
burnings's Avatar
Thanks for all the input.. shall do that and test again...
